SOLD -Astrolux MF02 - 3,000 lumens, 1587 meter throw - $49
MSRP: $314
Sales is as is!
In new-like, mint condition. Only used a few times.
The Astrolux MF-02 is a high-intensity, long-range LED searchlight featuring a Cree XHP35 HI emitter. It delivers a maximum output of 3,000 lumens and an extreme throw distance of up to 1,587 meters. It runs on four 18650 batteries housed in a reversible carrier
Specifications & Performance
  • LED Emitter: Cree XHP35 HI (Cool White 6500K
  • Peak Beam Intensity: 630,000 cd
  • Maximum Throw: 1,587 meters
  • Brightness Modes:
    Moonlight (15 lm), Mid (350 lm), High (1700 lm), Turbo (3000 lm)
  • Special Modes: Tactical Strobe, SOS, Location Beacon
  • Waterproof Rating: IPX-7
  • Dimensions: 189mm (length) x 84mm (head diameter) x 54mm (body diameter)
  • Weight: 818g (without batteries)
  • User Interface & Operation
Switch: Single body-side electronic clicky switch with a built-in indicator light.
On/Off: Press to turn on, long-press to turn off.
Changing Modes: Short clicks cycle through brightness levels (Moon → Mid → High).
Turbo: Double-tap the switch from any mode.
Special Modes: Triple-tap the switch to access Strobe, SOS, and Beacon.
Lockout: Long-press from off engages electronic lockout to stop accidental activation.
  • Battery & Power Details
Configuration: 4 x 18650 cells in a 2s2p arrangement via an included battery holder.
  • Standby Drain:
    Features a small parasitic drain (~3mA) due to the illuminated side switch, which drops under 1mA when electronically locked out. Turning the tailcap slightly breaks the physical circuit entirely for long-term storage.
  • Indicator Light: Displays green when power is above 50%, shifting to pulsing red and low modes as battery percentage drops.
PM sent, funds sent.
Light received in perfect shape, thank you.
