MSRP: $80
Sales is as is!
Included:
- Flashlight head
- Short tube
- Extension tube
- two 26650 lithium-ion batteries
- Tail cap
- Lanyard & lanyard ring
- Product box
The Convoy L6 is a powerful, high-output, dual-26650 battery flashlight known for offering exceptional brightness and solid build quality at a budget-friendly price.
Key Specifications:
Brightness: Max output 3,800
- Battery: Powered by two unprotected 26650 lithium-ion batteries with extension tube, or on unprotected 26650 lithium-ion battery in the short tube configuration.
- Dimensions: Length of 255mm, head diameter of 75mm, and a tube diameter of 35mm.
- Weight: Approximately 550g (without batteries).
- Water Resistance: IPX6 or IPX8 rated depending on production batch/spec specifications.
Design and Features
- Reflector: Utilizes large aluminum alloy orange peel reflector to balance throw and flood.
- Heat Management: Features a large integrated head and deep cooling fins that act as an efficient heat sink for extended high-output runtimes.
- Build: Rugged silver anodized aluminum body with aggressive knurling for secure grip.
- User Interface: Tail Switch: A physical forward-clicky mechanical tail switch handles main power (on/off) and momentary activation.
- Side Switch: An electronic side switch controls mode changes and special functions.Modes: Standard spacing includes 1%, 10%, 40%, and 100% brightness levels with mode memory.Strobe: Double-clicking the side switch from any mode activates the strobe function
