SOLD - Imalent RT70 - 5500 lumens, 903 meter throw - $39
MSRP: $195
Sales is as is!
In new-like, mint condition. Only used a few times.
The Imalent RT70 is a high-performance, portable search flashlight delivering up to 5,500 lumens and a 903-meter beam distance using a single Cree XHP70.2 LED. It features magnetic USB recharging, a side-pressure switch interface, and runs on four button-top 18650 lithium-ion batteries.
Key Specifications:
  • LED Emitter: Cree XHP70.2 (2nd generation)
  • Max Output: 5,500 lumens
  • Max Beam Distance: 903 meters
  • Power Source: 4 x button-top 18650 batteries (protected cells recommended)
  • Charging: Built-in magnetic USB charging port
  • Weight: ~420 grams (without cells varying by kit)
  • Operation & User Interface
On/Off: Single click of the side switch turns the light on or off.
Changing Modes: Press and hold the switch while on to cycle through regular brightness output levels.
Turbo & Strobe: Double-click the switch to activate Turbo mode; a second double-click activates Strobe mode.
