MSRP: Brass/Copper: $65 each, Titanium: $80 each
Asking:
- Brass & Copper Set: $60
- Titanium Polished & Sandblasted Set: $80
Sales is as is!
Raw flashlight with long tube only. Battery and short tube not included.
The Lumintop GT Nano v1 is a micro-sized keychain thrower flashlight powered by an open-source firmware.
Key Specifications
• Emitter: Osram KW CSLNM1.TG LED (cool white, ~6500K)
• Max Output: 450 lumens
• Peak Beam Intensity: 23,400 cd
• Max Throw: 350M meters
• Battery: Single 10440 Li-ion battery
• Driver / Firmware: Texas Avenger FET driver running NarsilM v1.3 (open-source GPL, adapted by Texas_Ace)
• Reflector: 20.8 mm smooth aluminum reflector
• Material & Finish: Aluminum with Type III hard-coat anodizing (also released in limited titanium/brass variants)
• Waterproof Rating: IPX8 (submersible up to 2 meters)
• Dimensions: 53–54 mm length × 24 mm head diameter × 14 mm body diameter
• Weight: ~17–21g (without battery)
User Interface & Features
• NarsilM UI: Features a smooth ramping interface by default, plus instant access to a 2.5A Turbo mode (via a double-click) and an alternative discrete mode-set option with 12 pre-defined mode sets.
• Charging: Uses a screw-on mini charger adapter with a micro-USB port that replaces the head during charging, featuring a glowing white indicator light.
• Switch: Tactile electronic side/tail switch with a back-lit rubber boot.
