SOLD - Lumintop GT4 4xLEDs 25000LM 1370m Flashlight Bundle (8 batteries, Lens cap) $139
It’s been quite awhile since I last posted here or even bought in a group buy. Over the years, I amassed a large flashlight collection; but probably smaller than some here. Most of them have only been used a few times; sometimes to show off to friends or just to be impressed with the light output. Well, regrettably, it’s time to let some go.
MSRP: $425
Asking: $139 $275
In mint condition.
What’s included:
  • Lumintop GT4
  • 8x button-top unprotected 18650 cells
  • Lens hood
  • Spare o-rings
  • Original box
NOTE: Optional handle not included.
Sale is as is!
Specifications
Emitter: 4x Cree XHP70.2 LED, neutral white or cool white, mounted on copper DTP MCPCB
Flux: >25,000 lm
Intensity: >469.1 kcd (ANSI throw >1370 m)
Firmware: Tom E’s open-source NarsilM v1.3 adapted by Texas_Ace
User interface:
[1] By default the GT4 is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 21A TURBO mode is also provided.
[2] A more conventional discrete level MODE-SET UI is available as an alternative. Anyone of 12 pre-defined mode-sets can be selected.
[3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
Battery: eight button-top unprotected 18650 cells . Protected cells will not fit.
Driver: 12V, Texas Avenger V2
Reflector: 118 mm inner diameter, aluminum, smooth finish
Lens: Glass with anti-reflective coating
Body: Aluminum with Type III hard-coat anodizing
Tripod socket: Standard 1/4 inch threaded (1/4-20 UNC)
Button: Tactile with back-lit rubber boot
Ingress rating: Equivalent to IP65, do not immerse in liquids
Weight: Approximately 2.6 kg without cells
Dimensions: 135 mm Ø head x 318 mm length
GT4 uses free software distributed under the terms of the GNU Public License version 3
GT4 Anduril code from toykeeper/flashlight-firmware
