It’s been quite awhile since I last posted here or even bought in a group buy. Over the years, I amassed a large flashlight collection; but probably smaller than some here. Most of them have only been used a few times; sometimes to show off to friends or just to be impressed with the light output. Well, regrettably, it’s time to let some go.
MSRP: $749
Asking: $319 $379
In mint condition.
Sales is as is!
What’s included:
Lumintop GT94
8x button-top unprotected 18650 cells
Lens hood
Handle
Shoulder strap
Carry bag
Spare o-rings
Original box
Specifications
Emitter: 4x Luminus SBT90.2 LED cool white, mounted on copper DTP MCPCB
Flux: >20,000 lm
Intensity: >1500 kcd (ANSI throw >2450 m)
Firmware: Tom E’s open-source NarsilM v1.3 adapted by Texas_Ace
User interface:
[1] By default the GT94 is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 21A TURBO mode is also provided.
[2] A more conventional discrete level MODE-SET UI is available as an alternative. Anyone of 12 pre-defined mode-sets can be selected.
[3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
Battery: eight button-top unprotected 18650 cells . protected cells not fit. Cells are not included.
Driver: 12V, Texas Avenger V2
Reflector: 118 mm inner diameter, aluminum, smooth finish
Lens: Glass with anti-reflective coating
Body: Aluminum with Type III hard-coat anodizing
Tripod socket: Standard 1/4 inch threaded (1/4-20 UNC)
Button: Tactile with back-lit rubber boot
Ingress rating: Equivalent to IP65, do not immerse in liquids
Weight: Approximately 2.6 kg without cells
Dimensions: 135 mm Ø head x 318 mm length
