MSRP: $529.95
Asking: $199
Sale is as is!
Package includes:
Lumintop Tiger 58000lm 1315m 21700 Flood Thrower Flashlight, with battery
Handle
Adapter and charging cable
Manual
Specification:
Emitter: 1Cree XHP70.3 HI+7Cree XHP70.2 HD LEDs
Flux: 58000 lumens
Intensity: 433000kcd(ANSI throw 1315 meters)
Power: 612W(max)
Firmware: Anduril Firmware with defaulted smooth Ramping UI. Instant access to a TURBO mode and mode settings are also provided.
Battery: Four 21700 battery. Flat-top and unprotected cells with max length 71mm (include)
Lens: Gass with anti-reflective coating
Protection: Reversed protection, over-charged protection, over-discharge protection, over-heat protection
Body: Aluminum with TYPE III heard-coat anodizing
Handle bar: Included
Lanyard hole: Available:
Tripod socket: Standard 1/4 inch threaded(1/4-20 UNC)
Button: Tactile with back-lit rubber boot
Ingress rating: Equivalent to IP68
Weight: Approximately 1745g with cells and handle
Dimensions: 93mm(head)*174mm (length)*63mm(tube)
With USB Type-C Quick charge/discharge function. Discharge as power bank function, support maximum discharge current of 5A. for the detail can check with the User manual.
