I would like to sell an Eagletac M25C2 Turbo that I modded a few months ago. This light has a 92mm head that throws a very nice, tight beam. Here are the specs…
Dedomed XM-L2 U4 1A on a 14mm Tpad
16mm Noctigon Glued (with thermal adhesive) Under Led Shelf (for extra heatsinking)
Fet+1 with Bistro (currently set to 1 mode…100%)
Forward Clicky Tailswitch
Comes with original box and accessories (cloth body cover, 2 spare o-rings, pocket clip :person_facepalming: , and a lanyard)
This light was measured at 636,763cd which is a total of 1,595 meters of throw.
I’m asking $135 shipped in the US via priority mail. This light isn’t very easy to find and isn’t all that great stock…but modded…it’s a beast! It runs on one 18650 (unprotected for best performance) button top or flat top.
Unscrew the tube from the rest of the light, unscrew the portion of the light that is screwed in below the reflector. From there, you’ll have direct access to the led, you’ll have to desolder it, push the negative (black) wire through the hole in the shelf…get a nail and cut the sharp end off or grind it down…put it in the hold that the negative wire was in and tap it with a hammer. The driver will come out fairly easy. It’s just press fit. The good news is that it’s a piece of cake from there. The driver itself is soldered to a contact board via a couple of short wires…cut the wires and you can piggyback a 17mm fet on the contact board.
Thank you so much! I am looking forward to my own mod.
