ALL SOLD
Up for sale are Four TWO ONE LEFT of the Ultrafire F13 lights.
They have been modified in the following ways:
The stock driver has a resistor removed, (pink highlight), to bring it to 4 modes. H/M/Strobe/SOS. The positive has been moved ahead of the resistor block, making it DD, (Blue Highlight). The Capacitor, (Yellow Highlight), has the lead pencil mod, so that the modes reset to high after turning the light off. The green is just showing the normal led ground position. The drivers did 3+ amps in my testing.
The locating rings have been sanded off on both sides, so that the reflector sits just a bit lower. This one hasn't been cleaned up, but they are were, before installation.
The stars were changed to Noctigons and the wires were soldered outboard, at the edges of the pads, so the reflector does not touch the wires. The wire is 22ga.
All the springs have the Copper braid mod, for less resistance.
The shiny bezels have been painted black, with matte clear coat, to stop the bright outer ring from showing up in the beam.
Silicone grease was applied to the tail caps and tail end of the bodies, to help lessen the "loose tail cap" syndrome. These tail caps aren't ever going to strip out, even though they are somewhat loose. The silicone grease helps a lot. It can be found in the pluming sections of most hardware stores.
These are somewhere between Cool to Neutral white. My camera never does capture the tint very good at all.
These lights come with an 18650 sleeve, a 3xAAA battery holder and a Lanyard. Two of the lanyards are green and Two of them are Brown.
CONUS ONLY International would be an added $15 and I don't think anyone wants to go there.
Price is $25 each, Shipped. ONE left, one with brown lanyard and one green.
Payment is PayPal oldlumens(insert the @ sign here)gmail.com
Post here that you want a light and if you want more than one, post how many, so others know what is left.
Follow that post with a payment and a PM to me, with your full shipping info.
Thank you
