Gently used, not dropped, pocket clip has been on and off a couple times, $40 shipped conus to a loving home.
has low battery warning light, USB battery included
has mode memory including for moonlight
It is 5500k, Im letting it go because I prefer Warmer colors, but this Olight is a really nice piece. Great form factor, super light weight, and the unbeatable Olight UI
And its the first Mini with a High CRI LED. Yes it has green tint if you use it for whitewall hunting, but in actual use, you might not notice. And the LED is the Color Temperature of Natural Sunlight.
The light for sale is pictured on the left.
The TIR beam makes a large throwy hotspot, good for outdoors, and it clips to a hat. The light weight and deep clip makes it really easy to use as a headlamp. The focused TIR beam makes it really good at cutting through the darkness efficiently without needing to use maximum power all the time.
