Up for sale is a silver 2D maglite modified with XHP-70.2 and FET +1 dual channel driver. The emitter sits on a 32mm maxtoch DTP copper MCPCB which in turn is adhered to a copper wrapped aluminum heatsink with arctic alumina. The reflector is a smooth rebel unit and the lens is the UCL unit from flashlightlens.com. The driver is flashed with star dual channel firmware featuring low-med-high-turbo modes, off time memory, a 60 second turbo timer, and low voltage protection. Battery positive is routed past the switch directly to the emitter to reduce resistance and prolong switch life. This maglite draws around 16 amps off a pair of liitokala 26650 cells for an estimated 8000 lumens out the front. The beam is fairly throwy with minor artifacts only visible on a white wall. I will try for beamshots tonight.
Price includeing CONUS shipping is $93. International buyers pay additional shipping.
That was a quick sale. I was hoping we might still get the beam shots.
I built several of these with xml’s and one with a mt-g. Heavy duty host and easier to work on than some of the small lights.
