- SOLD LOCALLY OUTSIDE OF FORUM
Spyderco Techno
Blade: CTS-XHP
Handle: Titanium
Used, with signs of wear, and in excellent condition.
Blade is absolutely perfect and professionally sharpened at Knifewear.
Buttery smooth deployment. Blade nicely centered. Solid lockup.
No box.
$SOLD - Shipped to USA (via USPS with tracking)
Shipping to Canada, please contact for quote
Please see detailed photos.
Manufacturer Description:
Polish knifemaker Marcin Slysz marks his Techno folder with a progressive European appearance.
The Techno falls into Spyderco’s “Little Big Knives” category; meaning it has a smaller blade and handle, paired with a hard-duty locking mechanism, exotic blade steel and vault-like construction found primarily on hard-use, larger knives. Spyderco’s first collaboration with Mr. Slysz, the Techno is also the first main-line production Spyderco CLIPIT® to use Carpenter’s Steel CTS-XHP. Knife steel metallurgists refer to CTS-XHP as having the steel properties and hardness of D2 carbon tool steel but with the added advantage of chromium to classify it as a powdered stainless steel.
Ground fully flat, the blade has an oversized Spyderco Round Hole and slide-resistant jimping perched on the spine. The handle is titanium with contrasting blue handle spacers leaving the handle open and exposing the inner workings for ease of cleaning. A Chris Reeve Integral Lock (R.I.L.) incorporates the handle’s back scale as the lock. With the handle’s back side doubling as both handle and lock, the need for internal liners is dispensed with, and the knife can be manufactured lighter and slimmer while retaining greater strength. A deep pocket wire clip can be positioned for left-hand or right –hand use with the blade tip positioned with the tip upward in the pocket.
Overall Length 5.98” (152mm)
Blade Length 2.55” (65mm)
Steel CTS XHP
Closed Length 3.43” (87mm)
Edge Length 2.33” (59mm)
Weight 3.6oz (102g)
Blade Thickness .177” (4.5mm)
Handle: Titanium
Origin: Taiwan
