I have a couple things I want to offer as I don’t use them and others might appreciate them.
Minimum on each is $65 paypal/shipped to Cont. USA I will close offer on 9/15/2018 6PM PDT
1) Surefire Executive Elite E1e
Some edge wear on the bezel which is marked KL1, no box, just the light. There are tons of replacement heads available for these. (Sure-Fire KL-1 LED Conversion Head consists of a bezel/lamp assembly fitted with a digital regulator, a three-watt LumaMax LED, and a custom designed light-focusing lens. The primary benefit of Sure Fire LED Lamp Conversion Heads KL 1 over a standard incandescent lamp is runtime. LEDs produce light more efficiently at low wattage levels, so a battery that is too depleted to run an incandescent lamp still has plenty of life to power an LED. The drawback to most LEDs is that they do not produce a steady amount of light as the battery drains. However, SureFire LED Conversion Heads differ from other manufacturer’s LED flashlights by using a digital regulator (KL1 & KL3) to maintain a consistent level of light output for as long as possible, while also protecting SureFire LED module from current and heat-related damage. SureFire is the first to utilize these breakthrough features in a hand-held LED flashlight.)
More pictures… https://imgur.com/a/3Sgr7sd (I suck at macro shots)
2) 4Sevens Maelstrom REGEN MMR-X
With tailcap switch conversion kit and extra orings. No box, no holster; with original battery which charges inside the body thru a micro USB connection hidden by a threaded slipring midbody. A standard 18650 battery may also be used to power the MMR-X. Before installation, the plastic insulating disc must be unscrewed from the tailcap using a pair of needle-nose or snap-ring pliers inserted into two holes. The insulating disc is then placed into the battery tube so that it prevents the outer spring from contacting the positive terminal of the standard 18650 battery. A standard 18650 battery cannot be recharged via the circuitry in the MMR-X.
INFO: http://flashlightguide.com/2014/04/review-foursevens-maelstrom-regen-mmr-x/
More pictures… https://imgur.com/a/BwtBiiJ (I suck at macro shots)
