MSRP: $89.50
Sale is as is!
I’ll be posting a lot more lights; around 40 more soon. So to save time, I’ll upload actual photos upon request.
Batteries not included!
The Nightwatch Stalker NI40 is a high-output, single-battery thrower flashlight featuring a Type III hard-coat anodized aluminum body. It pushes anywhere from 2,400 to 5,000+ lumens depending on the emitter choice (such as SST40, XHP50.2, or SBT90.2) and runs on an unprotected flat-top 26650 cell.
Key Specifications & Performance
• LED Options: Luminus SST40, CREE XHP50.2, Luminus SBT90.2, or SFNS5
• Max Output: 2,400 lm (SST40) up to 5,000–6,200 lm (SBT90.2 / SFN55)
• Throw Range: ~548m to over 938m depending on the emitter
• Dimensions: 53mm head diameter x 153mm length
• Weight: 254g (without battery)
• Body Material: Type III hard-coat anodized aluminum with stainless steel bezel
• Ingress Rating: IP68 (waterproof up to 2 meters)
• Switch: 20mm, 10A reverse tail/forward-style switch
Battery & Power Requirements
• Cell Type: 1 x 65mm unprotected flat-top 26650 Li-ion battery (not included)
• Fit Warning: Protected 26650 cells (~70mm) and 21700 cells generally do not fit due to stiff springs and tight spatial tolerances; protected cells can also trip under high current draws.
• Safety Features: Reverse polarity protection, low-voltage warning, and an active thermal step-down that triggers at 50°C.
User Interface & Modes
• Standard Modes: Low, Medium, High, and Turbo progression (or variations depending on specific batch/driver).
• Strobe: Accessible via a quick triple-click (or double-click depending on firmware version).
