Crelant 7G5-V2 xml-U2 Version... Including the Collimator head ...Mint condition 80$ shipped conus
pic thanks to: Mizjif
sold!
edit: pm sent
Wow, 8 minutes! That was fast
Very fast ..
it was 4 minutes before I edited the post :bigsmile:
i geuss i was asleep at the mouse! nice grab!
The one I’ve already got will finally get finished up for my uncle. I think I was subconsciously avoiding it because I didn’t want to give it up.
It will get xre-r2 green instead of SST-90 green though, since the latter would be a waste of a high power emitter in this light (lack of heatsinking, but more importantly, lack of room for driver).
So someone is selling one, the buyer really wanted one. Great.
In general (I keep this and the turbo head on my short list) I have only heard good things about this unit and the large head…
What are peoples thoughts about the Crelant (I want to say there is a new model but it can’t use the old upgrade head?) - keep it on my to- buy list or is there something else they love that blows it out of the water.
I think the head still works on the new one. I got mine from mark, (username macedov?) and he can confirm for you. this is his site.
http://www.md-lightsource.com/
I prefer the old one because it can be used with 1x18650 or 2.
I’m not aware of anything in the same class that blows it out of the water (w/ aspheric), and I don’t think there’s anything to even match it at the price.
I had been on that site, will look again, think that is where I saw the new vs old issue w the upgrade head (?).
Don’t have an aspheric, yet, and I have heard the whole package is a quality light at a good price, may wait to see if they do U3.
Always a good Q to ask - would you buy one again? Thanks.
I just did ![]()
but I haven’t tried the new version and the 7g5v2 version sold here is out of stock everywhere except kaidomain, and they want too much money.
Now you baited the hook! I want one! Lunchtime, 6 minutes, must get on flashlight sites…fix jones!
The collimator head will also fit on the 7G5CS. That’s what i have it on.
The head will work just fine on the 7g5cs. It will only run on two 3.7v batteries though, unfortunately.
If you also get the 7g2cs, the battery tubes are interchangeable, and you can run it off of two 16340/18350. Two protected keeppower 18350 will not fit.
Thanks! I am on his site right now.
The U2 version is $23 less than the U3. (not much claimed difference in lumens output between the two). Plus the $$ head. Interestingly enough, he has one head listed in the accessory section and just the U3 version shows the head as an accessory.
(and I am conveniently trying to ignore that you have that head already mounted on your own!)(trying to leave work w/o suicidal urge to spend another $100 on lights and save my marriage…)
Says both versions are in stock, what is the best other price you have seen (KD?)…on something like this I might just be more comfortable going w a US supplier just in case.
How much do you notice increase in throw and tightness of beam w the aspherical head installed. Have you modded the driver (? your comment about green or UV led) for general usage?
I would not pay extra for emitter bin. I would buy it, use it for awhile, then when I wanted more oomph I’d put xml2 on copper star in it.
md-lightsource was selling the 7g5v2 w/ head for ~$85 for a short period of time when the new version came out. I don’t expect you’ll see these get much cheaper until the next version comes out (6 months to a year, guessing on previous releases). Mark’s price on those, w/ BLF coupon code, are tough to beat. I don’t think he has a crelant coupon code active anymore. There’s no way I’d buy from kaidomain over mark unless they beat him by a considerable margin.
The throw about doubles with the aspheric head. I have an extra pill, and the first one I bought is getting a green led and going to my uncle for pig hunting at night.
I will probably leave the stock driver in the original pill, but upgrade the emitter to de-domed xml2.
I’m not sure what I’ll do with the one I just bought, but I don’t keep many lights stock lol
The reason only the U3 version has the head listed as an accessory is that he doesn't have anymore of the heads in the Gray finish. I picked up the last one.
Coupon BLF or BLF10 should work to take off 10%.
I think you're better off going with the u2 version for under $70. The bump in power, ~30 lumens is not worth it. Also I'm not liking the new UI as much... if the tailcap is on, you can use the side button for 1 click on, 1 click off.
With the new version, instead of, OFF, you get medium, ANOTHER press is needed to turn it off with the side button.
Appreciate that on the emitter - I don’t have a U2 vs U3 to compare (and never have all the tints anyway) and quickly forgot information from the thread where output was measured and weighed.
Double the throw - wow! I may need a new ‘range’ to play at, I think.
Guess I need to go read some more about those lenses - I understand the concept as it pertains to camera lenses, eyeglasses, but no experience w flashlights, other than reading some threads. As long as I can upgrade the driver at some point, it becomes more interesting to me and more likely to be a valuable purchase that I hold onto.
Appreciate all the other information offered (and updates) as well!
The aspheric head is something else altogether, it more than doubles throw.
I fell in love with what it does. Some people like it, some do not, since it does mean seeing the diode outline when up close. Now if only we could round LEDs instead of square ones, I would be in light heaven :p
you might experiment with a pre-collimating lense if you don’t like the square die and lines
I think its awesome, to me it visually accentuates how spill free the beam is (corners). Plus, Non-flashaholics are like “WTH is thaT?!”
