SOLD -
Show to the left , The gold Mag 1D host is made by Modamag, Custom grooves & Golden coated with TiCN not sure if spelled correctly, which is know for its golden color and surface hardness and chemical resistance.
This a special host as I don’t think there’s be more custom modamag coating runs after last fiasco and delay & wait time over a year etc.
The battery adaptor is white & made by Modamag, included, for 1x18650 use.
He machined a nice o-ring groove, so the adaptor fits snug, no rattling.
The Led is Illumination Supply Tint 3B XPG2, sweet neutral
It’s bare led that I re-flowed directly to Copper sink pad, where led is directly solder to copper, the best PCB design for heat transfer and allow high current draw efficiently from led, allowing XPG 2 to be driven to almost 3 Amp.
The Driver is illumination supply 8x7135 2.8 Amp XML driver, over drive the XPG 2 to similar lumens as XML2 but higher throw because of smaller Die.
Driver configured to 3 mode low-med-high, no blinky or disco
The heat sink is H22A HAIII heat-sink for mag C, with top sanded flat so that I can mount the copper sink pad.
The Reflector is aluminum LOP, aluminum rather than plastic,will not melt and helps with heat sinking. It throw well and gives a perfect beam, by perfect beam I mean McGizmo PD level of beam quality but many times more brightness.
The tail cap is modified to recess the spring, making the 1C shorter than if using mag stock tail
Teflon sleeve silver coated copper core wires for high current use
The light has doom intact, perserve max lumens while providing throw
Asking only $149
S&H $10 in the USA
