This may be a dumb question, but how do you avoid shorting the cathode and anode when soldering to a bare strip of metal?
MCPCBs have a ceramic layer to electrically insulate the traces and pads, right?
The silver is 6mm wide, the same as the solder pad on the mtg2. This leaves the electrical connections ‘easily’ accessible for soldering wires underneath.
Made a few copper slugs for xml the same way, its just a bit fiddly, but worth it.
Is there a thread on how to mod the LED? When I look at an XM-L all I see on top is green and two tiny metal-looking squares. Are those the top pads?
Edit: nevermind, just tried it, they are top pads. Needed to scrape off the top layer first.
Thx, lurned sumthin knew today!
I have a sterling silver tail plate and key chain loop on an SS-5039 because that was the material I had at hand. It soldered with 60/40 just like brass. Maybe a bit easier because it corrodes less. Heat conductivity is like copper or maybe a tiny bit better.
