Hi,
I have a Tiablo A10.G that I’ve been trying to basically update to a more “normal” driver and more recent emitter.
I’ve been able to replace the driver with this:
http://www.shiningbeam.com/servlet/the-269/**NEW**–3-dsh-Mode-Regulated-Circuit/Detail
and I installed a Nichia 219 emitter on a 20mm PCB (from Illumination Supply).
I had some problems getting the driver secured (I had a separate thread on that today), but I think that I’m now good with that.
However, even after that, I found that it’s acting very strange.
When I click once, nothing happens. Second click, kind of dim beam, third click blink, 4th click off, etc. If I keep clicking, eventually it stops working, and when I pull the switch out, it smells like something is burning (not good, I know), but if I jumper the tailcap, the modes work ok.
So, I started looking at the tailcap switch. That switch has some circuitry on it, something that looks like a surface mount 3-pin regulator, and maybe a resistor, so I’m thinking that the tailcap switch may be more than just an on/off or momentary switch, so I’m looking to try to either modify the original switch, or replace it with some other switch.
I happened to have a McClicky from Lighthound awhile ago:
This switch actually fits the tailcap, but the problem is that the original switch made contact at the bottom of the switch (near the button), whereas that McClicky contact to ground is at the plate/ring at the spring end, but at least I know the dimensions of the switch I need is about the same as that McClicky.
Here’re some pics of the original switch setup:
The pieces:
The switch PCB (the 3-pin chip is on the right). Also notice that the trace goes around the PCB. When that goes into the holder, that trace contact the holder, and the holder goes into the tailcap, and that’s how it all connects to the body and the negative side of the emitter driver.
and the switch in the “holder”:
I guess, ideally, I’d like to make the original switch act like a normal switch, but I’m a little concerned about the burning smell, and because when I keep clicking the light stops working, so probably the best would be to find a switch that I could use to replace the original switch.
Can anyone suggest something to replace this?
Thanks,
Jim
Edit: Correction: This is the McClicky that I tried:
http://www.lighthound.com/McGizmo-McClicky-Pak-Switch-Module-with-holes-no-boot_p_3210.html
In this picture:
that metal semi-ring around the spring is what is suppose to contact negative, whereas, as mentioned above, with the original Tiablo switch negative contact is on the switch/button end.
Edit 2: I just realized that the whole tailcap from my C8s fit the Tiablo A10.G!! That seems to work fine now, and no more burning odor :)!
BUT, I noticed a new problem now: I only have a single mode. I think it’s high, because the tailcap current is showing 2.25 amps, but not 100% sure. I checked to make sure than none of the stars on the driver PCB are bridged, and also checked for any other solder bridges, but everything looks ok, so what else could cause the board to be only 1 mode?
