[Solved] SkyRC MC3000 Firmware Update Issue
Hey guys,
I just received a new SkyRC MC3000 charger and have been enjoying using it, well until now. I saw that my firmware was old compared to the one listed on SkyRC’s website, so I figured I would update it. I downloaded both the monitor software and the firmware packages, followed the instructions, and as the charger was updating, this error popped up. “start vector err1”
The update pauses and doesn’t do anything. I clicked OK and it still didn’t do anything. My charger now has a completely blank screen and I’m freaked out that it may be one very expensive brick :cry:
Anyone have any idea on this? I saw a thread on CPF talking about this, but the member never got back to the thread on how to resolve it.
Any help would be very appreciated.
————————————UPDATE————————————
I was looking through CPF and found a thread where one of their members, TJH, came up with a guide to solve a firmware flash issue.
Here are the steps:
LINK TO THE POST ON CPF
Huge thank you to TJH for making this guide. I was really worried my charger just became a very expensive brick. Hopefully this will help someone else later on.
:+1:
Glad I could help :slight_smile:
Thanks for the instruction - it saved my day.
BTW, there is a new firmware update for the SkyRC MC3000
Thank ChibiM! Looks like the update is to support the new phone app. No information on other changes.
Ah, I only noticed a new update.. without looking into the details ;)
If the above doesn’t work try the following.
  1. With MC3000 USB/Power cables unplugged, press and hold the “Enter” key on charger, then plug in the power cord.
  2. Plug in USB Cable
  3. Open MC3000_Firmware_Update__V1.21.exe
  4. It should say “My device was found” followed by “Some data was send” (If you don’t get this message it already means your USB cable isn’t going to work, so try differen’t cables until you see your device was found.
  5. Click Update
  6. If the update stops and you get any vector error codes, you must try multiple different USB ports until the update works. Contrary to popular belief, you can use USB 2.0, 3.0, and even 3.2 Gen2 10g USB ports. Mine just so happened to work with a 3.2 Gen2 10g USB port.
  7. If all else doesn’t work, try a different computer because it should update eventually.
Hello,
there is now MC3000 firmware 1.23 from 2025-05-28
any idea what changes are there?
Thanks
There is some speculation over on CPF that it has to do with measuring IR. But as usual, SkyRC is hardly effusive with information on FW releases.
