OK pinkpanda send me a MTG2 light
I want to use that in the Jaxman Z1 host
So I need a driver to make it and me happy.
Also in the box was a SST90
I am thinking about putting that in my Courui D01
China vendors please since shipping is killing US deals
And the SST90 is on a copper square board
I found a round ALU board for it on kaidoman but hmm ALU
So I can just dremel it round right? Or is there a round star I can reflow it on?
For the Z1 i could make you a 17mm zener modded fet driver and use it over the 22mm board.
As firmware i normally use 5 modes with no blinkies , or i could try the new biscotti(mini bistro) firmware .
I have been googling but cannot find if the SST90 can be reflowed onto a MTG2 board.
So for that I’ll just cut the square down to fit.
Still no driver though but it is a 3V led capable of high amps so a fet driver fitting would be awesome I think.
I have reflowed several SST-90 emitters onto Maxtoch 26mm MT-G2 MCPCB's. It is possible to do and have it work. The SST-90 doesn't do much justice till you get it close to 10 amps. At low amps it is not impressive. Just my thoughts.
Thanks!
Now let me start with the reflow then and if that works I’ll need a driver that pumps out lots of amps
I think TA has a driver board designed to fit the Courui
That is for fet
