Some users who need to conduct durability testing on batteries may consider using the Gyrfalcon S8000 or S4000 Pro + TC. By utilizing custom test sequences to record data and perform regular checks, they can observe the capacity degradation after 50, 100, or 200 charge/discharge cycles. Of course, this kind of testing requires a long period. For example, if seven charge/discharge cycles are performed every two days, 105 cycles can be completed within 30 days.
Is there a carry case available to put the unit & ps in?
Calling all Linux users of the Enova Gyrfalcon chargers to help test my port of the Upgrade Tool:
TIA everyone!
That’s a cool program. Is there a list of supported multimeters anywhere? (Apart from inside the actual program.)
(I’m waiting for a new multimeter to arrive, but highly doubt it will be compatible.)
Of course, although some models are missing in the list.
https://lygte-info.dk/project/TestControllerSupportedEquipment%20UK.html
Here is an extended feature to share: by going to TC → Other →Text: Generate Configuration Copy Script, you can automatically generate a script to save the current program or easily copy all programs to another charger.
#scriptMenu Gyrfalcon_S4000Pro_Configuration_Copy_Script_20260224000547
#logcmds 0
=var device=getDevice("Charger")
(device):
=var channel = "None"
=var command_PreprocessBeforeSettingProgramQ = "CONTrol:PROGram:PREProcess? " + channel
=popupShowProgressAsync("Configuring GYRFALCON S4000Pro programs",32);
;;Start
CONTrol:PROGram:PREProcess (channel);[200];
#if (deviceRead(device,command_PreprocessBeforeSettingProgramQ) == "Ready")
;;Details of program 0
;;Battery Type: LiionStd
;;Task: Charge
;;Max Capacity: 5500mAh
;;Precharge Current: 0.1A
;;Max Precharge Time: 180min
;;Precharge To Fast Charge Voltage: 3.0V
;;Charge Current: 0.8A
;;Max Charge Time: 600min
;;End Charge Current: 0.1A
;;End Charge Voltage: 4.2V
;;Restart Voltage: 0.0V
;;Program Long Name: CHLI↑0.80A┍4.20V
;;Program Short Name: CHLI↑0.80A
;;Configuration Script of Program 0
=popupShowProgressSetPosition(0);
PROGram:SERIalno (channel),0;[50];
PROGram:TYPE (channel),Li;[50];
PROGram:TASK (channel),C;[50];
PROGram:CAPAcity (channel),5500mAh;[50];
PROGram:CURRent:PRECharge (channel),0.1A;[50];
PROGram:TIME:PRECharge (channel),180min;[50];
PROGram:VOLTage:PREChargetofastcharge (channel),3.0V;[50];
PROGram:CURRent:CHARge (channel),0.8A;[50];
PROGram:TIME:CHARge (channel),600min;[50];
PROGram:CURRent:TERMination (channel),0.1A;[50];
PROGram:VOLTage:TERMination (channel),4.2V;[50];
PROGram:VOLTage:RESTart (channel),0.0V;[50];
program:LongName (replaceCharsR("CHLI↑0.80A┍4.20V","\x7f\u2191\u2193\u29bb\u23b2\u2195\u22A5\u2126\u250d\u2515"));[50];
program:ShortName (replaceCharsR("CHLI↑0.80A","\x7f\u2191\u2193\u29bb\u23b2\u2195\u22A5\u2126\u250d\u2515"));[50];
CONTrol:PROGram:SAVE (channel);[50];
;;Details of program 1
;;Task: Charge
;;Configuration Script of Program 1
=popupShowProgressSetPosition(1);
PROGram:SERIalno (channel),1;[50];
;;Details of program 2
;;Task: Charge
;;Charge Current: 1.0A
;;Program Long Name: CHLI↑1.00A┍4.20V
;;Program Short Name: CHLI↑1.00A
;;Configuration Script of Program 2
=popupShowProgressSetPosition(2);
PROGram:SERIalno (channel),2;[50];
PROGram:CURRent:CHARge (channel),1.0A;[50];
program:LongName (replaceCharsR("CHLI↑1.00A┍4.20V","\x7f\u2191\u2193\u29bb\u23b2\u2195\u22A5\u2126\u250d\u2515"));[50];
program:ShortName (replaceCharsR("CHLI↑1.00A","\x7f\u2191\u2193\u29bb\u23b2\u2195\u22A5\u2126\u250d\u2515"));[50];
;;Details of program 3
;;Task: Charge
;;Configuration Script of Program 3
=popupShowProgressSetPosition(3);
PROGram:SERIalno (channel),3;[50];
;;Details of program 4
;;Task: Charge
;;Configuration Script of Program 4
=popupShowProgressSetPosition(4);
PROGram:SERIalno (channel),4;[50];
;;Details of program 5
;;Task: Charge
;;Configuration Script of Program 5
=popupShowProgressSetPosition(5);
PROGram:SERIalno (channel),5;[50];
;;Details of program 6
;;Task: Charge
;;Configuration Script of Program 6
=popupShowProgressSetPosition(6);
PROGram:SERIalno (channel),6;[50];
;;Details of program 7
;;Task: Charge
;;Configuration Script of Program 7
=popupShowProgressSetPosition(7);
PROGram:SERIalno (channel),7;[50];
;;Details of program 8
;;Task: Charge
;;Configuration Script of Program 8
=popupShowProgressSetPosition(8);
PROGram:SERIalno (channel),8;[50];
;;Details of program 9
;;Task: Charge
;;Configuration Script of Program 9
=popupShowProgressSetPosition(9);
PROGram:SERIalno (channel),9;[50];
;;Details of program 10
;;Task: Charge
;;Configuration Script of Program 10
=popupShowProgressSetPosition(10);
PROGram:SERIalno (channel),10;[50];
;;Details of program 11
;;Task: Charge
;;Configuration Script of Program 11
=popupShowProgressSetPosition(11);
PROGram:SERIalno (channel),11;[50];
;;Details of program 12
;;Task: Charge
;;Configuration Script of Program 12
=popupShowProgressSetPosition(12);
PROGram:SERIalno (channel),12;[50];
;;Details of program 13
;;Task: Charge
;;Configuration Script of Program 13
=popupShowProgressSetPosition(13);
PROGram:SERIalno (channel),13;[50];
;;Details of program 14
;;Task: Charge
;;Configuration Script of Program 14
=popupShowProgressSetPosition(14);
PROGram:SERIalno (channel),14;[50];
;;Details of program 15
;;Task: Charge
;;Configuration Script of Program 15
=popupShowProgressSetPosition(15);
PROGram:SERIalno (channel),15;[50];
;;Details of program 16
;;Task: Charge
;;Configuration Script of Program 16
=popupShowProgressSetPosition(16);
PROGram:SERIalno (channel),16;[50];
;;Details of program 17
;;Task: Charge
;;Configuration Script of Program 17
=popupShowProgressSetPosition(17);
PROGram:SERIalno (channel),17;[50];
;;Details of program 18
;;Task: Charge
;;Configuration Script of Program 18
=popupShowProgressSetPosition(18);
PROGram:SERIalno (channel),18;[50];
;;Details of program 19
;;Task: Charge
;;Configuration Script of Program 19
=popupShowProgressSetPosition(19);
PROGram:SERIalno (channel),19;[50];
;;Details of program 20
;;Task: Charge
;;Configuration Script of Program 20
=popupShowProgressSetPosition(20);
PROGram:SERIalno (channel),20;[50];
;;Details of program 21
;;Task: Charge
;;Configuration Script of Program 21
=popupShowProgressSetPosition(21);
PROGram:SERIalno (channel),21;[50];
;;Details of program 22
;;Task: Charge
;;Configuration Script of Program 22
=popupShowProgressSetPosition(22);
PROGram:SERIalno (channel),22;[50];
;;Details of program 23
;;Task: Charge
;;Configuration Script of Program 23
=popupShowProgressSetPosition(23);
PROGram:SERIalno (channel),23;[50];
;;Details of program 24
;;Task: Charge
;;Configuration Script of Program 24
=popupShowProgressSetPosition(24);
PROGram:SERIalno (channel),24;[50];
;;Details of program 25
;;Task: Charge
;;Configuration Script of Program 25
=popupShowProgressSetPosition(25);
PROGram:SERIalno (channel),25;[50];
;;Details of program 26
;;Task: Charge
;;Configuration Script of Program 26
=popupShowProgressSetPosition(26);
PROGram:SERIalno (channel),26;[50];
;;Details of program 27
;;Task: Charge
;;Configuration Script of Program 27
=popupShowProgressSetPosition(27);
PROGram:SERIalno (channel),27;[50];
;;Details of program 28
;;Task: Charge
;;Configuration Script of Program 28
=popupShowProgressSetPosition(28);
PROGram:SERIalno (channel),28;[50];
;;Details of program 29
;;Task: Charge
;;Configuration Script of Program 29
=popupShowProgressSetPosition(29);
PROGram:SERIalno (channel),29;[50];
;;Details of program 30
;;Task: Charge
;;Configuration Script of Program 30
=popupShowProgressSetPosition(30);
PROGram:SERIalno (channel),30;[50];
;;Details of program 31
;;Task: Charge
;;Configuration Script of Program 31
=popupShowProgressSetPosition(31);
PROGram:SERIalno (channel),31;[50];
CONTrol:PROGram:COMPleted (channel);[50];
=popupShowProgressSetPosition(100);
#endif
;;Finished
Load the above script into TC and run it to complete the copying process.
