Streamlight macrostream replacement
I’ve used a macrostream for many years now. I recently lost it and am searching for a replacement. I loved that light, the only thing that bothered me was the micro usb connector.
I’ve looked at many options but haven’t found any great ones. I’m mainly looking for:
  • small (long but skinny)
  • tail switch
  • usb c rechargeable (preferably on the light and not on the battery)
  • battery that’s intended to be replaced
  • tail switch
Olight has some options but they seal in the battery, as has the thrunite archer mini. A few other possible options include the lumintop aa, acebeam pokelit aa, acebeam rider rx, convoy t3, thrunite saber and the nitecore mt2a pro, but all of these have the usb c port on the battery and not the light body.
The only two contenders I’ve found so far are the wuben c3 and the nitecore mh11, but these are both quite a bit larger (though I’m sure more 18650 lights with a usb c port exist).
I don’t need anything fancy, low + high mode is totally fine. CRI and brightness don’t matter either (I usually carry a bigger light around for demanding stuff but I want something pocketable).
Acebeam Tac 2AA. ACEBEAM TAC 2AA $49.90
USBC rechargeable (unfortunately it’s the battery) but will also run on 2 regular AA batteries. Tail switch for momentary and to turn off and on, (choose either mode memory or turbo) and side switch to change modes.
LED choices for either a throwy or floody beam. I don’t have one, but I’ve given two away as gifts, and they’ve been well received.
Great choice. On sale for $25.49 at US Amazon right now.
That’s a phenomenal deal!
1x14500, USB-C on the flashlight body, and tailswitch is the Fenix LD12R… and I think only the Fenix LD12R.
Thanks for all of the suggestions. After a lot more research I found the Speras Est Mic, it fits perfectly. Usb c on the body, tail switch with 3 modes and removable 10440 battery.
Make yourself at home, Ilosariph!
It is not “Micro USB C” it is just Micro USB.
the macrostream form factor is tricky to match. wurkkos fc11c is probably closest to what you described — usb-c on the light, tail switch, 18650 so a bit thicker but still slim in hand. nichia 519a option if you care about tint.
the acebeam pokelit and rider put the usb-c on the battery not the light so if the micro usb port on the macrostream bugged you those might annoy you the same way. lumintop aa is great but no onboard charging at all, you would need a separate charger.
convoy t3 with usb-c 14500 cells works but same thing — charging on the battery not the body. honestly for thin + usb-c on light + tail switch + replaceable battery the fc11c is hard to beat at that price.
FC12C tailswitch + side button,
FC11C Sideswitch and magnetic tail cap
both have usb c and buck driver.
cheers
:flashlight:
What the hell was I thinking when I wrote that lmao. You’re right ofc.
Get Wurkkos FC12C
usb-C, buck driver, include battery
forward clicky switch
slim profile
Cheers :flashlight:
