Streamlight Protac 1AA Xp-g to Nichia
Thanks again to what I’ve learned from this forum I was able to replace the xp-g in my Streamlight Protac with a 4500 Nichia 519a. I boiled the light a few minutes in a plastic bag and was able to twist the head off. The driver and LED unthreaded out and there was a white spacer over the LED. I only had to un solder in remove that PCB. I have some 14 mm boards with LEDs coming, but I got impatient so I used the stock board and reload the 519 A onto it. On my first try, I did not have good contact but watching the video in this forum I took the LED back off and make sure I had it in the correct orientation and it did work. I really like this light and now I like it a lot better with this emitter.
7 Thanks
Well done! How’s the brightness compared to before?
Better I think, at least not less. And the high CRI is awesome.
where might i find a board for this? i love my streamlight (same as yours) but the tint is so cree. i cand lo LED swaps except for the whole mcpcb. it would be glorious for me to throw maybe a 25r 5000k from simon in here, or a 519a like you did.
I’ve gotten mine from Mtn Electronics, they have various LEDs which you can have mounted on different sized mcpcb’s.
and its 14mm pcb?
Yes, 14mm.
I’m envious and will attempt this myself. Thank you!!
Edit: My original 1L-AA will only take AA’s now, the contact for CR123’s broke after 5-6 years of AA use. This will be a good opportunity to get in there to fix it! :grin::grin:
what would slicing the original led do?
