I can't comment on the C8 lights from DinoDirect, only the one from Manafont I mentioned. A lot of times, the ultra-budget C8s aren't driven strongly and you don't get the full brightness. The C8 I reference has a decent driver that goes Direct-Drive on high which makes it an extremely bright light.
Also a lot of people here have had bad experiences with DinoDirect not shipping what they advertise as well as poor follow-up experiences from the CS team. I've only bought from them twice but I didn't have any issues with my purchases...
The 501/502/503/504 type hosts will make a nice light, but a decent LED drop-in will cost nearly as much as the full C8. They are smaller, but are not very impressive throwers due to the much smaller reflector.
And finally, do NOT use salvaged laptop cells for gift lights unless the recipient is technically capable, aware of the dangers, and knows proper charging/cell handling procedure! I use salvaged laptop cells in some of my lights, but I STRONGLY recommend you purchase PROTECTED cells for gifiting.
You can’t go wrong there, believe me. Best part is that you can run it on high for as long as the batts can take it and it will not overheat. Massive heatsink is why. For the money that aspect alone at this price-range it’s not surpassed by any other single XML on the market, period. Much less its overall quality of construction from A to Z. And the version the above seller provides has the extension tube. You can run 1 x 18650 or 2 x 18650.
And yes, it’s really BRIGHT with plenty of throw and big spill combined. IMO, prolly the most underrated torch out there for the bucks. And the seller above me sells the genuine TrustFire X8. Many clones out there that are inferior.
An amazing light. It’s a Q4 emitter but it acts like a quasi-T6 with really big punch. With brightness and focus out of such a small torch that it has to be seen to be believed.
What a torch for less than $15. And talk about quality construction. It’s that good.
I would recommend the sipik sk98, but its not perfect. Crazy driver and it would be better to add a small heatsink in it.
The wf501 compared to a c8, makes the bigger head the light not more incomfortable for a jacket or so?
I ask because i am on the search as a adequate change to my burned one?
