Hi,
I’m new here. Looking for some good human centric lighting.
Couple of years ago I’ve found after many tests the budget Arena Lighting high CRI Ra97, high R9 97, low blue, it seems good quality treated blue leds…
BTW, I’ve found here that @maukka has tested them (5th position
). My test has been my eye and spectrum curve from the supplier. As the bulb is GREAT with pleasant lighting we have bought n°24 of those. Not available any more at 3200K.
They have today the replacement one, moreless at 2900K (too warm for us)
Waiting for the “Purple” leds + Tri-R at normal budget to equipe all the home; I’ve seen and bough n°20 of Sun@Home E27 bulb from LEDVANCE, high CRI, low blue, they claim SUNLIKE full spectrum; so it should be the purple led + tri-r treatment from Toshiba etc.
Dimmable, 2200 - 5000K…with tri-R…at 9.7eur per unit/bulb at 5 years warranty, at discount, it is THE DREAM
Even wanted to order n°10 more but as usual I double check things and something has not be so clear, at least for me as I don’t have a instrument to be objective and measure (and not technical knowledge for this speciality)
As the light of the bulbs is pleasant, Colors are well rendered, I’ve ordered also the Sun@Home PANON panel for my son desk, also the Sun@Home desk lamp to test etc.
All of this up to the constructor is the 2200-5000K wifi dimmable, full spectrum SUNLIKE. So ALL WITH THE SAME LEDS (should be 3030 from seoul semiconductors)
BUT, I’ve been surprised when I’ve discovered that the spectrum curve supplied from the EU certification site IS NOT the same for on, for on one side “bulbs” (e27, e14, par16) and on other side for panels, integrated led lamps etc???
The panels like PANON have the spectral curve for CCT 5000K that looks like the real SUNLIKE purple led tri-r model (as in their marketing presentations)
The bulb range Sun@Home has, up to their EU certification docs, the spectral curve similar to the “true light” blue leds or a little better than the best treated blue leds, but with huge blue light part, it is ok, but with the hole in the turquoise part of the spectrum. And this curve is not the case for the true SunLIKE purple led + tri-r…at least up to my understanding or I’ve missed something?!
Before I’ve found it and before my order, I’ve asked LEDVANCE support to send me the “bulbs” test curves.
They have sent me the curve for 5000K, thanks to them, so like it is for the E27 bulb.
But I’ve found that it is not for bulbe , it is for the PANON product range (so real sunlike).
With the QR code from the packaging, I’ve discovered the link to the docs where it is completely different for the “bulbs” (more similar to improved blue leds???)
If someone can help to understand this.
Maybe #Maukka
here the images that explains my doubts and the claim that I’ve sent to LEDVANCE, but no answer from them.
we’ll see as if not I’ll not miss the return window for n°20 bulbs e27.
Maybe this is the error, we are 25th November 2022 today, that Ledvance will correct in their certification documents for CE EU, who knows, real strange, or they might mixed some different leds inside for bulbs (I’ve seen 100.000 on/off cycles guaranteed for bulbs, and only 10.000 to 15.000 cycles for panels…maybe related to the leds, maybe power supply)
The GOOD point is that it looks fine for the panel and lamp model, but I don’t have the spectrophotometer to compare to bulbs.
Cheers
