Sunwayman just released new single 18650 sized flashlight, its veri nice model, form factor just like MH20
As you can see it is available in 2 colors, features integrated USB charger
You can find out more about this light by visiting manufacturers website > http://www.sunwayman.com/fo/pd_152_en.html
Here are the specs from Sunwayman web site:
Features ● CREE XM-L2 U3 LED, with a lifetime of up to 50,000 hours; ● Slightly depress the side switch to turn on/off the flashlight as well as selecting desired output mode: Turbo (1000 lumens, automatically lowers to High after 3 mins continuous use); High (580 lumens, 2 hrs ); Mid (130 lumens, 10 hrs ); Low (40 lumens, 35 hrs ); Strobe; SOS; Aviation Signal ● USB charging interface, can be charged by laptop, charger baby or direct power supply ● Constant current circuit, constant output ● Effective range of 208 meters ● Uses one single 18650 or two CR123A batteries ● Working voltage: 2.8~8.4V ● High quality metal smooth reflector maintains great throw distance and spread with an ideal beam pattern; ● Dimensions: 110.5mm (length) x 32mm (head diameter) x 27mm (tail diameter) ● Weight: 88.3g(battery excluded) ● Aerospace-grade aluminum alloy, Stainless Steel retaining ring on the top ● Military Specification Type III- hard anodized body ● Waterproof, in accordance with IPX-6 standard ● Ultra-clear tempered glass lens resists scratches and impacts ● Accessories: Clip, Lanyard ,O-rings
I think it will be a good MH20 competitor with lower price
What do you think, would you like black or silver version?
Update 01-22-2016
First batch is in the warehouse and will be ready for shipping in 1-3 working days...
Coupon code has been distributed, please hurry, code is valid till monday 25th...
The new model seems be good.
But sunwayman’s customer service is suck.
I had malfuntion C22C. So I emailed them for RMA.(with two accounts)
But they never read and answered my emails.
I read that another blf member had same experiences.
In the other hand. Skilhunt service is great.their feedback is quite fast,…
They repaired H02 in two days with tracking number.
Really faster than nitecore.
I got same experience from fenix, i have tried to email them about my LD40 where the thread on the plastic body is worn out but never get any response.
Sayonara from me for fenix :Sp
It’s close call but i like silver one a bit more
XP-L HI would be nice, yes.
For price, please PM me…
As per customer service I had good experience, contacted them about broken driver for T40CS (not in warranty anymore) they responded within a few days, shipped the driver within a week, no payment required.
Lumintop has a new light out in the same form factor as well (with XP-L HI as an option). I think it looks really nice too. Someone should get all of them for a comparison review
The lumintop looks better with XPL HI choice. But what is going on with the 30-40 lumens low? Thanks but no thanks!
The last sunwayman I got was G25C and it supposedly has 16 lumens. Turns out it was more like 60-70lumens.
I really like the looks of this one. The description says “constant current”, I don’t know if they are referring to constant current to the LED, or from the driver. it’s a pity it doesn’t use XP-L HI, paired with that smooth reflector this could’ve been a nice compact thrower.
This c23c looks badass in the silver color. The design is quite appealing too. Imo, better than the manker and nitecore, but that lumintop looks best.
This light would do pretty well in a group buy I suppose.
They forgotten to add a magnet in the tail end tho
I’ve had a couple of dealings with Sunwayman service, very good on both occasions. I had a light fail, and repaired under warranty, and a new light had chips on the tail cap, and they replaced the tail cap.
