The V10r Ti+ reflector does not make a good beam w 219b (will try to find a pic), and the stock 5050 mcpcb is not compatible…
you can use a warm XM-L2 or switch mcpcb to use LH351d
the V10r Ti+ Reflector works much better w LH351d than with 219b or SST-20
because the base of the reflector has a hole that is too large for the small die LEDs… and results in a dark shadow ring in the spill… bad beam…
you can buy a 12mm 3535 board for LH351d here
there is no reflector upgrade available for Sunwayman Rotaries, that I know of
fwiw, the V11r and V10r Ti+ use the same reflector… I recently modded a V11r to LH351d 2700k… It turned out to have a really nice beam…
I recommend that LED…. but dont shave it or you get the shadow ring again:
here is the difference between the V10r Ti reflector, and the V11r/V10r Ti+ reflector:
(the centering rings are different too)
if you want to use 219b it can help to improve the beam if you lift the mcpcb on a 0.5mm shim (copper sheet, or thermal expoxy, or … I have also used thermal tape for that purpose)… you could also remove the stock centering ring and use a flat centering ring instead (its not an exact match to the reflector hole… getting the LED centered will require a little fiddling).
It is still possible to use sw45k and sw30 happily in a V10r Ti+… just dont be too critical when you shine the beam on a wall…
any 219b is better than no 219b… and LH351d in any other CCT than 2700K is not really as good as the 219b alternative, in my very pro 219b biased opinion… I only suggest LH351D Warm due to the larger face of the LH351d being a good match for the V10r Ti+ reflector. The 219b actually has higher R9 CRI than the LH351d. In addition to the LH351d having greener Tint.
fwiw, there is word of a 2700k 219b that has recently become available from Hank. its not listed… I have not tried it… you would need to email him…
why I love 219b tint more:
