**I got lucky.
After discussing the parameters of a light which I hoped to find or have built, Richard (owner/operater of Mountain Electronics, LLC, a favorite supplier here on BLF) told me he had been working on a promising prototype, a highly modded Supfire M6. I offered to buy the prototype if/when it was completed to Richard’s satisfaction.
I have that torch in my hands. I’m still giddy about the shape, the size, the heft, the finish and the comfort-in-the-hand. As for wall beam shots, I literally put on sunglasses to further inspect the beam (for non-existent abnormalities.)
(I haven’t had the appropriate amount of time to use the light in enough settings to feel that I can reliably report on lighting performance. I can tell you that the UI is simply the finest side swith mode I have in my rather large light collection.)
Now, I’ll let Richard outline the mod specs for you:
-Emitters: 3 x XM-L2 T6 3C neutral white LEDs on Noctigon direct thermal path star.
-Driver: Custom built ultra-low-resistance-direct-drive FET with fast (non-visible) PWM. Low voltage ramp down (warning) and shut off, at ~3.0v and ~2.8v respectively. Can be overridden by user by holding down power button for emergency situations if batteries are drained.
-User Interface: Six useful modes, 45 second step down from high to prevent overheating (can be overridden). Short press cycles modes forward, long press (~0.35 seconds) cycles modes backwards. This means from an off position, you can start in either the highest or lowest mode.
-Power Level: Dependent on cells used, as they are the limiting factor. Four Samsung 20R cells draw over 18A. Protected cells can be used but output will be reduced depending on cell type and protection circuit resistance, button top type recommended.
-Lumen Output: 4,000 lumens at startup with four Samsung 20R cells.
Unless you absolutely have to do your own mods on this terrific budget host, I am confident in recommending the modded Supfire M6 by Mountain Electronics. (Numbers 2 through ??? shoukld be just as nice as #1.)
