16-7-2014 11:03:12 Full Shipment Your order has been fully shipped.
14-7-2014 15:49:13 Order Processing Order is being prepared for Shipment.
14-7-2014 6:08:33 Order Processing Order is being processed.
14-7-2014 6:08:33 Payment Confirmed Payment verified.
14-7-2014 6:08:26 Order Received Order has been created, awaiting payment
Just as I was about the leave the office, the shipment of 3 packs came in.
Yellow envelope looks fine but once I open, it doesn’t look too good.
1. The plastic battery case for 2 of 3 packs are broken. All are cracked in various sides. Several rubber bands hold the case together. Case is Soshine branded
2. None of the 12 cells have any kind of markings or labels. Pure clean purple wrap
3. Slight oxidation at the cells bottom plate
4. Flat top not button, slight recessed more that usual
5. Cell top is off center in roughly half of the 12 cells.
6. No scratches
7. 4 cells test 120-150 mOhm in Opus BT-C3100 Quick Test.
I’ve thrown 4 into Opus BT-C3100 for a discharge test.
Photos later when I have time.
These are the more interesting ones…
These are 4.35V cells, but I’m charging them at 4.2V
Nevertheless, as I understand, I should at least get close to 3000mAh.
This is disappointing…
The off-center flat top is a sure give-away to the cells quality. I don’t know what those cells are, but I’m sure they are not from the major makers like Panasonic, Sony, Sanyo, LG and Samsung. Might be 2200 mah cells as shown by their consistent discharge capacities.
i dont recall any samsung cells with that bumped out negative.
so who knows what you have?
wouldnt try 4.35 either!
might be ok generic cells by those readings though.
I’ve cancelled my order. I’m convinced this is fake. Different wrap, different bottom, no marking - pretty obvious by these alone. The poor capacity and inconsistent internal resistance are also regular with chinese cells.
Really wished DX has given more days for me to decide :_(
Do you think they will give full refund easily? Or should I reject the registered package at door and ask postman to return to sender (if there is a return address)?
