I’m measuring tailcap amps of a Thrunite TC15 in turbo mode with a Uni-T 210E. I got smoke and the lens fogged up. My meter read around 9.5A before I broke the connection.
Any ideas why this would be - the torch is still working ok - but I’m only doing the job of the tailcap with the lead running through my clamp meter?
Just running turbo mode with the tailcap installed I don’t get smoke obviously.
Ok thanks. I didn’t short anything as far as I know. I’ve done this before with other torches and it seems to be common practice so trying to figure out how I could avoid this in future?
Do you reckon any damage done to torch? The smoke came from the head of the torch, and the inside of the lens fogged up.
It might be that there’s enough resistance in the tail cap spring to keep the current below smoking point, and the lower resistance from the wire puts it above smoking point.
Question is, where’s the smoke coming from?
(Edit: I realise you just posted “The smoke came from the head of the torch, and the inside of the lens fogged up.” as i was posting but i meant in a more specific way, i wouldn’t expect an LED to smoke though it may happen. I think it’s more likely some contamination on the LED/in the head, or maybe a component. What LED is it?)
Yes that makes sense - it’s the only thing I can think of since otherwise what I’m doing is the same as having the tail cap on. It happened quickly - but the smoke just appeared at the head of the torch.
i just find that tail cap measurements are always sort of dangerous - close tolerances, nothing is fused, lithium battery can blow up, it may be in a confined tube [-> rocket mode], your meter in current mode is a short, if you happen to think ‘let me measure this voltage here’ OOPS
Ok, so 9.5A would be just over 3A @ 12V which is def pushing an XHP35, so could be the LED. I’m not familiar with how the XHP35 destructs.
There’s mention in this thread about them maybe ‘randomly combusting at 3A’ but that’s all i know and don’t know what that constitutes: https://budgetlightforum.com/t/-/43473
Specks of dust on the reflector or LED surfaces can turn to smoke at high output. Dust on an LED can damage the silicone or phosphor when it burns, which is why LED cleanliness is critical for high output flashlights. I think residual soldering residue / flux can create smoke as well, at a lower temperature than would melt the solder.
The tailcap bypass probably sent more current to the emitter than normal and something burned as a result.
