not quite sure the sponge will work. maybe too spongy and soft and may collapse. i would try and find the tallest/thickest sponge so the more you can stick in the s2.
or maybe you can use a styrofoam cup, put the sponge inside the cup, turn the cup over, place it on the ground, and just take your s2 and poke a hole through the top of cup.
now the s2 will have a perfectly sized hole, so no wiggle room, and it will be basically sitting on top of the sponge. and that cup is acting as your base.
Yup. And if the s2 slides through the hole, then just wrap some rubber bands around the body ,slide the rubber bands head first. So now the top part of body if bigger than the lower part that’s inside the hole in the cup.
But I do like Boaz idea. I may use that one day. I like that u can angle it.
Wait a minute now! I posted this in the very first reply:
“Maybe using the larger of these type clamps? Clamp around the base of the light as a stand or even clamp around the middle if you wanted to prop it up at an angle for more directionality. Seems (in my mind) it might work.
WorkPro Clamps”
and Boaz gets credit for the idea
