Got one of these for $4.02 after reading this deal alert (Post 1167) by tru3s1lv3r.
That beamshot above from the product page doesn't seem realistic. Maybe for the 18650 version, but I still doubt it. I got the 3AAA version and the output is nothing close to that and the beam profile is throwy (small tight hot spot).
It's not a bad light. The Head and Pill are aluminum, but the rest is plastic. . It needs a floodier beam as the output really only makes it useful for closeup stuff. Only mod I have done to it so far is swapping in a Nichia 219C D280 5000. It increased output, CRI, and helped make the beam profile a little less throwy. Think I will eventually throw in a TIR to make is more floody. The reflector is nice if you like a throwy beam profile, but the lens is plastic. The "XPE" is on a mcpcb labeled LatticeBright.
Anyway, here are a few shots for anyone wondering what is inside. You have to remove 4 screws from the back to open up. The bill unscrew from the back (has some weak glue between it and the plastic. That is all you have to do to access everything.
Driver, motion detector back and front. It's direct drive. The resistors marked "2R0" control current to the LED. They are parallel for a combined resistance of 1 ohm. If one wanted to increase output, the skinny LED leads should also be replaced with thicker wires.
