I have wanted to take one of these apart for years to understand how it is put together and I finally got around to it.
I want to design a very similar ultra-minimal light for myself from scratch, and I figured there would be some good lessons to learn from disassembling one of these.
I purchased two, knowing I was likely going to damage the one I disassemble, since there is no clear way of opening it.
This is a quite affordable LED-based lens zoom light with a non-removable 18650 cell and built-in USB C charging. Here are the pictures of it new:
To open the light from the back I used vice grips to hold the tail cap and unscrew it normally.
There is no switch contained in the tail cap, only a metal rod that is retained with a C clip on the inside and serves as a push rod that actuates a switch.
When the C clip is removed the tail piece tops out and you can see the spring and magnet.
The push rod actuates a push button switch on the PCB, which is mounted on the battery carrier.
The battery compartment has a single 18650 cell inside a plastic shell, with two PCBs mounted on either end.
USB-C inlet and charger side:
USB-C inlet underneath:
Driver side:
Not sure what kind of driver this is, probably linear, it seems quite simple.
Driver side underneath:
Removed from the cell you can see the two wires crossing over from one side to the other to give the driver and charger access to both positive and negative ends of the battery.
The charger also includes a small NTC thermistor for monitoring battery temperature during charging, a nice feature.
The battery holder makes this light significantly thicker than an 18650 cell, at 28mm diameter it is closer to a 21700 flashlight.
The battery is a 2550mAh EVE cell.
One last note about the bottom, the lanyard holes through the body are just two basic holes, and the loop-through interior curved shape is provided by a piece of plastic on the inside, not any kind of off-axis drilling or plunge EDM.
There is also a small steel bar for reinforcement.
The head of the flashlight was the hardest part to open. I had to use a heat gun to loosen some glue, and it turns out the head is threaded on, but with LEFT-HAND threads ![]()
Two o-rings provide sealing, although the light is only IPX6 rated, not water proof.
Here you can more easily see the two threaded and interlocking pieces of plastic that retain the head on.
It is two pieces because it has to be assembled over the larger diameter portion of the body tube with the two o-rings.
The LED has a precollimator lens over it as well as a white plastic dish likely to try collect as many lumens as possible OTF, even if not in the focused beam.
The front 25mm diameter main lens is held in from the back with a steel ring in a groove, which I was not able to remove. The front opening of the head is smaller than the lens diameter (22.5mm opening) so it is fully retained form the front.
Not sure what the LED is, likely some cheap Chinese XP-L HI clone or similar from what it looks like, on an aluminum MCPCB.
A very sad amount of thermal paste ![]()
The main flashlight body tube seems to be made out of two pieces of aluminum, which I was not able to unscrew so they may be press-fit together or glued.
One piece is the plain tube, the second piece is the front smaller diameter neck and O-ring portion.
Overall, a lot more thought went into this than I had originally predicted. I thought most of it was going to be press-fit together, but they actually have a design that can be disassembled and reassembled if you know what you’re doing.
Definitely learnt a lot and hope to make something similar (but better) in the future ![]()
Let me know if you have any questions about the light!
Cheers,
-Enderman
