Even though I have done it successfully a few times, its still a struggle. Not sure if its hot or cold that makes it easier to bridge solder when stacking 7135 chips. What temp. range do you guys use to do this? Thanks.
Remember that it's the total amount of heat, and how quickly that heat is transferred, that gets put into the work piece that really matters, so which tip you're using plays a huge part in what temperature you should use.
Colder temperatures make it easier to bridge, but you still have to put enough heat into the components to get the solder to bond on the molecular level. Tips that are too small can make the situation worse.
There are several ways to add 7135s, but here's what I do: I start by tinning all of the legs on the 7135s that are already soldered on the PCB. I then apply a little flux to the new 7135 legs. I heat the legs on the board first until I see that solder melt, then drag upwards onto the new 7135. The flux will wick the solder upwards onto the legs of the added chips.
I use a Hakko T18-B tip with the station set at 700 degrees (heating element degrees; not actual tip degrees). A thinner tip would require a higher station temperature to be relatively equivalent, and a thicker tip would require a lower temperature. You may have to experiment to find the sweet spot for your setup and style.
I assume you use paste flux, not liquid flux?
Either. It just really depends on what I've got in front of me. I used liquid flux exclusively until last summer, and still use mostly liquid flux. I use the MG Chemicals RMA flux. I bought a 125 ml bottle for about $8 and it will probably last me a few more years still. At first I was using it in a syringe, but that's too messy and hard to control for most uses, so now I use it in a flux pen (I refill the pen).
I’ll have to try your method tonight. I was having a terrible time last week, even tried using solder paste and “reflow stacking” (which failed miserably), I just couldn’t get it to bridge. I have some kester 186 in a dropper bottle, hopefully that will do the trick.
Reflow stacking will never work. Don't use solder paste. When you do use flux, it only takes a little bit.
It only took about 30 seconds to figure that out, but another 5 minutes were spent cleaning up all the connections I inadvertently bridged with the extra solder ![]()
He makes it look so simple and clean! :_(
And so will you, as soon as you develop the knack for it.
How do you get to Carnegie Hall? Practice, practice, practice.
More like Patience patience patience! :bigsmile:
I just watched the video and gave it a shot. Richard’s technique worked great. I think having the temperature low enough is the key, but bending the legs definitely makes it easier.
edit:
I had my station set at 700f as well, though I probably could’ve gone even lower.
I just watched the video. Definitely learned a few tips. BTW, that gator clip has seen some use, lol. Now, I thought I read some where that the middle prong isn’t necessary to solder? Is that true? Hopefully it is, or else I got a couplew lights I need to fix.
If you don’t solder the middle leg you have to solder the top wider ends together. If you have a look at the bottom side of the 7135s you’ll see that they are the same. This is ground, which has to be soldered to ground, either to the board or the chip it’s on top of. If you do it using the smaller middle leg or the top wider one is up to you, but ground must be connected.
Thats what I thought. I do the wider one. I know it was working though eithier way.
I thought about using the wide one myself but found it fairly easy to bridge the solder with the small legs bent. Never tried the wide side.
The first ones I did with the wide side, but I soon found that a lot of lights had clearance issues if you weren't really careful with the blob size.
That's my Harbor Freight helping hands---the same one I've used since the very beginning. I never thought it would last this long (I also never thought I would use it this much).
I got the same Harbor Freight helping hands. Works great!
