Mini-Mighty Bright EDC Flashlight Klarus Mi1C
Klarus Mi1C is a unique mini-mighty bright EDC flashlight barely over 2 inches in length. And yet, using CREE XP-L HI V3 LED and one high performance Klarus 16340 battery with micro-USB charging port, this “rechargeable” tiny light delivers 600lumens, with maximum runtime up to 9 days at moonlight mode.
Features
- Mini-might brightness, thumb-sized.
- CREE XP-L HI V3 LED, maximum output up to 600 lumens.
- Extreme runtime, up to 9 days in moon mode.
- Professional optical lens design, even-lit flood and soft beam.
- Tail magnetic base function, attach to a metal surface to provide “hands-free” illumination.
- Fade-in and Fade-out function when the turbo mode is the initial mode for on and off to promote eye safety and improve user experience.
- Newest Intelligent Temperature protection System(ITS) monitors internal temperature and adjusts output to regulate heat dissipation; protects LED and internal components for perfect balance of output and safety.
- Intelligent Battery Capacity indicator to view remaining battery capacity at any time.
- Unique lock-out mode prevents accidental activation; avoiding battery drains during storage or travelling and prevents unintended directly shining into eyes.
- Reverse-polarity protection prevents damage due to incorrect battery orientation.
- One-touch low and with mode memory function.
- Aerospace Aluminum Alloy construction; CNC precision machining; Mil-Spec HAIII anodizing, anti-abrasive, lighter and robust.
- Compatible with CR123A and 16340 Li-ion battery, KLARUS high performance 16340 battery with Micro- USB port included, no need to bring a charger, easy to use, safe and reliable.
Specifications
- CREE XP-L HI V3 LED, 50000 hours life.
- 4 lighting levels, 2 flashing modes.
- Working Voltage: 2V-4.2V.
- Compatible Batteries: CR123A x 1 or 16340 Li-ion battery x 1.
- Reflector: Convex Lens.
- Switch Type: Side Switch.
- Dimension: (Head)19.8mm(0.78") x (Body)20.5mm(0.81") x (Lenght)54.5mm(2.15").
- Net Weight: 27g (0.95oz) (w/o battery).
- Material: 6061-T6 Aluminum Alloy Body, Mil-Spec HAⅢ Anodizing.
- Waterproof: IPX8 (underwater 2 meters) .
- Included Accessories: Spare O Ring x 1, Stainless Steel Clip x 1, 16340 Li-ion Battery with Micro-USB Charging Port x1
If you are interested, notify in this thread (not in PM)
OFFER IS AVAILAIBLE !
Details via PM
My main thread: GearBEST.com Coupon Codes&Flashsales
My other groupbuy threads:
NITECORE DL10 ✺ Dual-light source DIVING light - Interest list ACTIVE
JETBeam TH20 ✺ Tactical flashlight XHP70.2 - Interest list ACTIVE
