Test / Review: AW IMR 18650 1600mAh (Red)
Official specifications:
  • Nominal Voltage : 3.7V
  • Capacity : 1600mAH
  • Lowest Discharge Voltage : 2.50V
  • Standard Charge : CC/CV ( max. charging rate 4.5A )
  • Cycle Life : > 500 cycles
  • Max. continuous discharge rate : 15C
  • Operating Discharge Temperature : -10 - 60 Degree Celsius
This cell is designed for high current and can handle up to 24A according to the specifications.
The batteries are shippend in a small plastic box.
I have tested with discharge currents up to 20A and the battery handles it without problems.
The battery might be useable up to 24A, but do not expect a long runtime, it is less than 5 minutes at 20A.
With the low capacity they are fast to charge and I could have charged them much faster if I had used the maximal charge rate.
Conclusion
The battery is good battery, but with the low capacity it is mostly for special high current applications.
Notes and links
Hm, up to 5A the Callies Kustoms 2250 keeps about the same voltage but with greater runtime, over that the AW has a clear advantage. I think I prefer the Callies due to greater runtime...
And the usual "thank you for a great test" :)
