Keeppower 18650 2900mAh (Black)
Official specifications:
- 18650 2900mAh Protected Rechargeable Battery
- Min Capacity: 2750mAh
- Typical Capacity: 2900mAh
- Normal Voltage: 3.6V
- Quality Lithium Ion rechargeable cell
- In Built Safety Circuitry
- Maximum capacity and reliability
- High Discharge Rate (Max 2C)
- Protection Circuit (Against overcharge, over discharge, over current and short-circuit.)
- 4.2 volts max voltage and 3.6-3.7 volts nominal voltage
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
Conclusion
With a 2900mAh cell the battery is slightly below the highest capacity batteries on the market, but not much.
I will rate this battery as very good.
Notes and links
Keeppower is a OEM manufacturer, i.e. many of the batteries they produce is sold with other names on them.
The batteries was supplied by Keeppower for review.
