2.1A Dual USB car charger
Official specifications:
Input Voltage: DC12V-24V
Output Voltage: 5V
Output Current: 2.1A/1A
Material: Aluminum Alloy.
I got it from Aliexpress dealer: Maintain_Your_Car Store
It arrived in a plastic bag inside a envelope, no instruction sheet included.
Measurements
USB outputs are coded as usb charger (DCP)
USB outputs are in parallel.
There is blue light inside the charger.
Weight: 19.2g
Length: 68mm
Diameter: 25.7mm
For a 2.1A rated output it is rather weak with overload limit at 0.9A
Slightly higher voltage did not help
With 24V input I got slightly above the 0.9A, but not for long and it did not work after that. This means no more tests.
Tear down
I could remove the front with a spudger and then pull the circuit board out.
The circuit has two capacitors, a rectifier diode, a inductor and a chip (AD85063: 5V 1A)
The reason the circuit stopped working is obvious, the chip could not really deliver the rated current and was low on protection.
There is nothing on the bottom.
Being a 12V device there is no need to test with high voltages.
Conclusion
This charger is over rated and the chip cannot handle overload, this is a rather bad charger.
Notes
Compare car chargers and other DC supplied chargers
