2USB inCharge PRO 55 12W
Official specifications:
Input voltage: 120 - 250V 50Hz
Input current: 0.5A
Output voltage: 4.75 - 5.25V
Output current: 0.01 - 2.4A
Output power: 12W
Energy efficiency >=86%
Standby power loss: <=50mW
When I started to open the box there was more instructions inside, both in English and German.
The box contained the charger, a instruction sheet and some clamps that can be used for mounting it.
The front can be removed by loosing one screw, the mains is still mostly protected.
Part of the usb circuit board can be seen when the front is removed.
The mounting clamp
Measurements
Power consumption when idle is 0.06 watt, that is about 0.5kWh/year
Both USB outputs is auto coding with DCP, Samsung and Apple 2.4A
USB outputs are in parallel.
Weight: 97g
Front is 55.3 x 55.3mm, metal plate is 71 x 71mm
Wall box hole: min. 53x52mm with a depth of 32mm (Instruction require 40mm)
Output can deliver a bit above 2.5A, this is very good for a 2.4A rated output
The output output is the same on the other plug.
The socket is not rated to work at 120VAC, but it will do it.
Running the two outputs in parallel do not increase power.
The charger has no problem delivering 2.4A for one hour.
My test is done in free air, this charger is supposed to be mounted in a wall, this can mean better or worse cooling.
M1: 57.9°C, M2: 49.8°C, HS1: 67.5°C
HS1: 48.4°C
HS1: is the rectifier transistor.
HS1: 59.9°C
The heat in this corner is either from the switcher transistor or from the snubber network (Maybe a combination).
HS1: 56.6°C
M1: 43.3°C, M2: 39.7°C, HS1: 55.6°C
Noise at 0.5A load is: 20mV rms and 476mVpp.
Noise at 1A load is: 26mV rms and 569mVpp.
Noise at 2.5A load is: 32mV rms and 604mVpp.
Tear down
I had to remove two small black screws then I could unclip the back and pull the usb circuit out.
The mains part of the circuit board is near the transformer. Where the mains wires are connected is a MOV across the mains, there is a inductor between the two mains smoothing capacitors (One on each side of the transformer). On the other side of the transformer is also a switching transistor (Q1).
On the low volt side is a rectifier transistor and a auto coding chip (RH7901A) behind each usb connector.
The distances are fairly small on this usb charger, to help a piece of plastic is glued into the slot.
On this side is the fuse and bridge rectifier, there is also the switcher controller and a safety capacitor. On the low volt side is a synchronous rectifier controller chip next to the low volt smoothing capacitor.
The distance across from the safety capacitor is about 6mm.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
For a charger hidden in a mains outlet it is fairly powerful and it has auto coding. The safety do also looks fairly good. Because it is always connected it is also important with a low standby power and it lives up to that.
But it can only do one fast charge at a time.
Notes
Charger was supplied by a smarterliving.nl for review.
How does a usb charger work?
