Ampsplus 18650 3500mAH (Black) 2020
%202020/DSC_2008.jpg)
Official specifications:
Battery Size: 18.40mm x 68.85mm
Nominal Voltage: 3.60V
Nominal Capacity: 3500mAh
Min. Rated Capacity: 3400mAh
Charging Method: CC/CV 4.20V +/-0.05V
Discharge Voltage: 2.70V (Average Cut Off)
Standard Charging Current CC: 1475mA
Standard Charging time: 270min.
Continuous Discharge Current: 10A
Protection Circuit Trip Cut Off: 2.75V
Battery rate: 3C
Weight: 49 gr.
Colour: Black, Silver, Purple
Protection Circuit Board / PCB: Yes/ Protected (Maxell)
Version: Button Top
Type: Rechargeable, High Drain, NCR
%202020/Ampsplus%2018650%203500mAH%20(Black)%202020-info.png)
This is high capacity protected 18650 battery with a fairly high current limit for a protected battery.
%202020/DSC_2007.jpg)
%202020/DSC_2010.jpg)
%202020/DSC_2011.jpg)
%202020/DSC_2012.jpg)
%202020/Ampsplus%2018650%203500mAH%20(Black)%202020-Capacity.png)
The two cells match nicely, but the protection do not protect a high continuous current, there I stop due to temperature.
%202020/Ampsplus%2018650%203500mAH%20(Black)%202020-Temp-10.0.png)
I forgot to mount the thermo sensor on one of the batteries.
%202020/Ampsplus%2018650%203500mAH%20(Black)%202020-Temp-15.0.png)
Even without thermo sensor it trips after some time at 15A.
%202020/Ampsplus%2018650%203500mAH%20(Black)%202020-CapacityTimeHours.png)
%202020/Ampsplus%2018650%203500mAH%20(Black)%202020-CapacityTime.png)
%202020/Ampsplus%2018650%203500mAH%20(Black)%202020-Energy.png)
%202020/Ampsplus%2018650%203500mAH%20(Black)%202020-PowerLoadTime.png)
%202020/Ampsplus%2018650%203500mAH%20(Black)%202020-TripCurrent.png)
%202020/Ampsplus%2018650%203500mAH%20(Black)%202020-Charge.png)
Conclusion
It is a good battery, but with the protection the maximum continuous current is about 10A continuous or 15A peak. The protection do also provide over discharge and charge protection (They always do).
Notes and links
The batteries was supplied by Ampsplus for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
