Ansmann C 4500mAh 5035352 (Silver)
Official specifications:
Nominal voltage: 1.2V
Maximum charge voltage: 1.5V
Nominal capacity: 4500mAh at 0.2C
Minimum capacity: 4500mAh at 0.2C
Minimum capacity: 4200mAh at 1C
Maximum continuous discharge: 6750mA
Standard charge: 450mA
Quick charge: 1350mA
Fast charge: 2250mA
Recommended termination: dv: –5mV, dT: 0.8 ~ 1°C/min, T: 45 °C 50°C
Trickle charge current: 45 ~ 150mA
Continuous overcharge: <450mA (no deformation or leakage within a year)
Internal impedance: <20mOhm at 1kHz with fully charged battery
Cycle life: >500
Low self discharge: >80% remaining after 12 months at 20°C
Ambient temperature: Standard charge: 0°C ~ 45°C, Fast charge: 10°C ~ 40°C, Discharge: –20°C ~ 65°C
This is a full capacity C cell from Germany (It is made in China and bought in Denmark).
Maximum temperature raise at different discharge currents: 1A:+0,4°C, 2A:+2,8°C, 3A:+4,6°C, 5A:+8,5°C, 7A:+11,6°C, 10A:+15,9°C, 15A:+20,9°C
Very well matching discharge curves and the cell easily match the rated capacity.
Conclusion
This looks to be a very good quality C sized NiMH battery with lots of capacity and low self discharge.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
