Aucooma IMR18650 2500mAh (Orange-green)
Official specifications:
Capacity Std. charge / discharge: 2500mAh
Nominal Voltage average of Std. Discharge: 3.70V
Standard Charge: Constant current: 1250mA, Constant voltage: 4.20V, End current(Cut off): 50mA
Fast Charge: Constant current: 4000mA, Constant voltage: 4.20V, End current(Cut off): 100mA
Max. Charge Voltage: 4.20V
Max. Charge Current: 4000mA
Standard Discharge: Constant current: 500mA, End voltage(Cut off): 2.5V
Fast Discharge: Constant current: 10000mA, 20000mA, End voltage(Cut off): 2.5V
Max. Discharge Current: Continuous discharge: 35000mA
Weight Approx.: Max. 48.0G
Operating Temperature: Charge: 0 ~ 50°C, Discharge: –20~ 75°C
Storage Temperature: 1 month: –20 ~ 60°C, 3 months: –20 45°C, 1 year: –20 20°C
Dimension: (D)18.3 + 0.2/-0.3 mm, (H) 66.0 ± 0.2 m
/Aucooma%20IMR18650%202500mAh%20(Orange-green)-info.png)
High current cells with moderate capacity.
/DSC_4205.jpg)
/DSC_4206.jpg)
/DSC_4208.jpg)
/DSC_4209.jpg)
/DSC_4210.jpg)
/DSC_4211.jpg)
/DSC_4212.jpg)
/Aucooma%20IMR18650%202500mAh%20(Orange-green)-Capacity.png)
Discharge curve tracks very nicely and keeps nearly constant capacity up to 20A.
The vertical line at the end of the curve is because I have stopped the discharge, but is still recording, i.e. it shows maximum temperature (gray line) and how much voltage the cell recovered (Red line).
/Aucooma%20IMR18650%202500mAh%20(Orange-green)-Temp-15.0.png)
/Aucooma%20IMR18650%202500mAh%20(Orange-green)-Temp-20.0.png)
The cell gets warm at 20A discharge, maximum temperature is just below 80°C
/Aucooma%20IMR18650%202500mAh%20(Orange-green)-Temp-30.0.png)
At 30A the temperature goes slight above 90°C.
/Aucooma%20IMR18650%202500mAh%20(Orange-green)-CapacityTimeHours.png)
/Aucooma%20IMR18650%202500mAh%20(Orange-green)-CapacityTime.png)
/Aucooma%20IMR18650%202500mAh%20(Orange-green)-Energy.png)
/Aucooma%20IMR18650%202500mAh%20(Orange-green)-PowerLoadTime.png)
/Aucooma%20IMR18650%202500mAh%20(Orange-green)-TripCurrent.png)
/Aucooma%20IMR18650%202500mAh%20(Orange-green)-Charge.png)
Conclusion
This cell is one of the very good high current cells with decent capacity.
Notes and links
The batteries was supplied by Aucooma for a review.
Compare to 18650 and other batteries
