AW 14500 750mAh (Black) 2016
%202016/DSC_4486.jpg)
Official specifications:
750 mAh Capacity
Nominal Voltage 3.7V
Diameter 14.33mm
Length 51.33mm +/- 0.1mm
Max. discharge rate 2C (1.5A)
Size for reference AA
PCB protection against overcharge, over discharge and short circuit
Safety vent with thermal cut off protection
%202016/AW%2014500%20750mAh%20(Black)%202016-info.png)
A “high capacity” protected AA sized cell from AW
%202016/DSC_4485.jpg)
%202016/DSC_4488.jpg)
%202016/DSC_4489.jpg)
%202016/DSC_4490.jpg)
%202016/AW%2014500%20750mAh%20(Black)%202016-Capacity.png)
This is not the most impressive discharge charts, the cells has different capacity. They have no problem delivering the rated 1.5A
%202016/AW%2014500%20750mAh%20(Black)%202016-Temp-2.0.png)
%202016/AW%2014500%20750mAh%20(Black)%202016-Temp-3.0.png)
At twice the rated current the cells warms up a bit.
%202016/AW%2014500%20750mAh%20(Black)%202016-CapacityTimeHours.png)
%202016/AW%2014500%20750mAh%20(Black)%202016-CapacityTime.png)
%202016/AW%2014500%20750mAh%20(Black)%202016-Energy.png)
%202016/AW%2014500%20750mAh%20(Black)%202016-PowerLoadTime.png)
%202016/AW%2014500%20750mAh%20(Black)%202016-TripCurrent.png)
%202016/AW%2014500%20750mAh%20(Black)%202016-Charge.png)
Conclusion
These cells is not the highest capacity in 14500 cells, the current handling is fairly normal for non-IMR cells. The length is fairly short for a protected cell.
I do not like the mismatched capacity.
Notes and links
The batteries was supplied by aw-akku.de for review.
Comparison to other LiIon batteries
