AW IMR16340 15C 550mAh (Red) 2016
Official specifications:
550 mAh Capacity
Nominal Voltage 3.7V
Lowest Discharge Voltage : 2.50V
Diameter 16.00mm
Length 34.00mm +/- 0.1mm
Max. discharge 8A
Size for reference CR123A
Working temperature –10 to 60 Degree Celsius
%202016/AW%20IMR16340%2015C%20550mAh%20(Red)%202016-info.png)
CR123 sized LiIon batteries that can deliver a lot of current.
%202016/DSC_5306.jpg)
%202016/DSC_5308.jpg)
%202016/DSC_5309.jpg)
%202016/DSC_5310.jpg)
%202016/DSC_5311.jpg)
%202016/AW%20IMR16340%2015C%20550mAh%20(Red)%202016-Capacity.png)
The discharge curves looks very goo, the batteries are rated for 8A and had a perfect curve at 7A, but has trouble at 10A. This looks good.
%202016/AW%20IMR16340%2015C%20550mAh%20(Red)%202016-Temp-5.0.png)
%202016/AW%20IMR16340%2015C%20550mAh%20(Red)%202016-Temp-7.0.png)
As usual with these small batteries the discharge is done before I can register much heat on the battery can.
%202016/AW%20IMR16340%2015C%20550mAh%20(Red)%202016-Temp-10.0.png)
%202016/AW%20IMR16340%2015C%20550mAh%20(Red)%202016-CapacityTimeHours.png)
%202016/AW%20IMR16340%2015C%20550mAh%20(Red)%202016-CapacityTime.png)
%202016/AW%20IMR16340%2015C%20550mAh%20(Red)%202016-Energy.png)
%202016/AW%20IMR16340%2015C%20550mAh%20(Red)%202016-PowerLoadTime.png)
%202016/AW%20IMR16340%2015C%20550mAh%20(Red)%202016-TripCurrent.png)
%202016/AW%20IMR16340%2015C%20550mAh%20(Red)%202016-Charge.png)
Conclusion
This 16340 battery looks to be a good high current battery.
Notes and links
The batteries was supplied by aw-akku.de for review.
Comparison to other LiIon batteries
