AW IMR18650 2200mAh (Red) 2016
Official specifications:
Nominal Voltage : 3.7V
Capacity: 2200mAh
Lowest Discharge Voltage: 2.50V
Standard Charge: CC/CV ( max. charging rate 2.2A )
Cycle Life: > 500 cycles
Max. continuous discharge rate: 20A
Operating Discharge Temperature:
1060 Degree Celsius -
Dimensions: 18.15 x 65.6 (+/-0.05)mm
%202016/AW%20IMR18650%202200mAh%20(Red)%202016-info.png)
A high current and fairly low capacity 18650 cell. This is one of the few high current cells with button top.
%202016/DSC_5282.jpg)
%202016/DSC_5284.jpg)
%202016/DSC_5285.jpg)
%202016/DSC_5286.jpg)
%202016/DSC_5287.jpg)
%202016/AW%20IMR18650%202200mAh%20(Red)%202016-Capacity.png)
Discharge curves looks very good up to 20A with very good tracking and nearly constant capacity, but the cell cannot handle 30A (Probably the reason it is rated for 20A).
%202016/AW%20IMR18650%202200mAh%20(Red)%202016-Temp-15.0.png)
%202016/AW%20IMR18650%202200mAh%20(Red)%202016-Temp-20.0.png)
The battery gets warm during a 20A discharge, but not too warm.
%202016/AW%20IMR18650%202200mAh%20(Red)%202016-CapacityTimeHours.png)
%202016/AW%20IMR18650%202200mAh%20(Red)%202016-CapacityTime.png)
%202016/AW%20IMR18650%202200mAh%20(Red)%202016-Energy.png)
%202016/AW%20IMR18650%202200mAh%20(Red)%202016-PowerLoadTime.png)
%202016/AW%20IMR18650%202200mAh%20(Red)%202016-TripCurrent.png)
%202016/AW%20IMR18650%202200mAh%20(Red)%202016-Charge.png)
Conclusion
The cell handles 20A fine, but the capacity is a bit low by todays standards.
Notes and links
The batteries was supplied by aw-akku.de for review.
Compare to 18650 and other batteries
