AWT IMR18350 700mAh (Yellow)
Button top version
%20BT/DSC_6519.jpg)
Official specifications:
- Rated Capacity: 800mAh (0.5CA Discharge)
- Rated Voltage: 3.7V
- Internal Resistance: <100mOh (with PTC)
- Cut-off Discharge Voltage: 2.75V
- Charge Upper Limit Voltage: 4.20±0.05V
- Charging Time(Std): 4.0hours
- Standard Charging Circuit: 0.2C A
- Charging Circuit: 0.5C A
- Standard Discharging Circuit: 0.2C A
- Fast Discharging Current: 0.5C A
- Max Discharging Current: 2C A
- Weight: about 21.5g
- Height: 65mm
- Operational Temperature: charge (0 ~ 45°C), discharge (-20 ~ 60°C)
- Storage Temperature: within 1 month (-20~ 50°C), within 3 months (-20~ 40°C), within 3 months (-20~ 20°C)
%20BT/AWT%20IMR18350%20700mAh%20(Yellow)%20BT-info.png)
This is a high current 18350 cell. It has 6.4A continuous and 10.5A pulse rating.
%20BT/DSC_6518.jpg)
%20BT/DSC_6521.jpg)
%20BT/DSC_6522.jpg)
%20BT/DSC_6523.jpg)
%20BT/AWT%20IMR18350%20700mAh%20(Yellow)%20BT-Capacity.png)
The is some capacity difference between the two cells. It easily handles loads up to 5A, but has problems at 7A and cannot do 10A.
%20BT/AWT%20IMR18350%20700mAh%20(Yellow)%20BT-CapacityTimeHours.png)
%20BT/AWT%20IMR18350%20700mAh%20(Yellow)%20BT-CapacityTime.png)
%20BT/AWT%20IMR18350%20700mAh%20(Yellow)%20BT-Energy.png)
%20BT/AWT%20IMR18350%20700mAh%20(Yellow)%20BT-PowerLoadTime.png)
%20BT/AWT%20IMR18350%20700mAh%20(Yellow)%20BT-TripCurrent.png)
%20BT/AWT%20IMR18350%20700mAh%20(Yellow)%20BT-Charge.png)
Flat top version
%20FT/DSC_6525.jpg)
- Nominal Voltage: 3.7v
- Capacity: 700mAh
- Standard charger: cc/cv(max ,charging rate 2A)
- Cycle Life: >1000cycles
- Max .continuous discharge rate:6A
- Operating Dishcharge Temperature: under10 and over 60 Degree Celsius
- Dimensions: 18.15x49.82mm
%20FT/AWT%20IMR18350%20700mAh%20(Yellow)%20FT-info.png)
Same cell as above, but this time in flat top version. It has slightly less capacity.
%20FT/DSC_6524.jpg)
%20FT/DSC_6527.jpg)
%20FT/DSC_6528.jpg)
%20FT/DSC_6529.jpg)
%20FT/AWT%20IMR18350%20700mAh%20(Yellow)%20FT-Capacity.png)
These cells handles 7A better.
%20FT/AWT%20IMR18350%20700mAh%20(Yellow)%20FT-CapacityTimeHours.png)
%20FT/AWT%20IMR18350%20700mAh%20(Yellow)%20FT-CapacityTime.png)
%20FT/AWT%20IMR18350%20700mAh%20(Yellow)%20FT-Energy.png)
%20FT/AWT%20IMR18350%20700mAh%20(Yellow)%20FT-PowerLoadTime.png)
%20FT/AWT%20IMR18350%20700mAh%20(Yellow)%20FT-TripCurrent.png)
%20FT/AWT%20IMR18350%20700mAh%20(Yellow)%20FT-Charge.png)
Conclusion
The cells has very good performance at high current, but the difference between the cells means that they are best used one at a time (i.e. not in series).
Notes and links
The batteries was supplied by AWT for a review.
Comparison to other LiIon batteries
