Basen 18650 3400mAh BS186A (Black)
/DSC_6488.jpg)
Official specifications:
- Capacity: 3400mAh
- Voltage: 3.7V
- Style: Flat top
- Protected: No
- Charging current: Maximum 2A (1A current recommended)
- Weight: 48.5g±1g
- Size:Diameter: 18.28mm; Length:65.20mm
/Basen%2018650%203400mAh%20BS186A%20(Black)-info.png)
This is the usual 3400mAh battery with a Basen label on and it works as expected.
/DSC_6487.jpg)
/DSC_6490.jpg)
/DSC_6491.jpg)
/DSC_6492.jpg)
I am not very impressed with the QR code, due to the round cell my phone will not read it.
/Basen%2018650%203400mAh%20BS186A%20(Black)-Capacity.png)
The cells has good tracking and is above the rated Panasonic minimum capacity (3200mAh at 0.65A discharge) and I do not even test the full capacity, because I stop at 2.8 volt, not the rated 2.5 volt.
I do not now what the bumps in one of the 7A lines are.
/Basen%2018650%203400mAh%20BS186A%20(Black)-CapacityTimeHours.png)
/Basen%2018650%203400mAh%20BS186A%20(Black)-CapacityTime.png)
/Basen%2018650%203400mAh%20BS186A%20(Black)-Energy.png)
/Basen%2018650%203400mAh%20BS186A%20(Black)-PowerLoadTime.png)
/Basen%2018650%203400mAh%20BS186A%20(Black)-TripCurrent.png)
/Basen%2018650%203400mAh%20BS186A%20(Black)-Charge.png)
Conclusion
There is not really anything to say about this battery, except it is a very good battery.
Notes and links
Compare to 18650 and other batteries
