Belkin Micro Home Charger
Official specifications:
Input Power: AC 100-240V 50-60Hz
Output Power: DC 5V-1A
1 USB Port
I got it in a cardboard box, it is supposed to contain the charger and a Apple charge cable.
Measurements
Power consumption when idle is 0.04 watt
Usb outputs are coded as Apple 1A
Weight: 40.2g
Size: 65.4 x 50.2 x 35.4mm
The charger can deliver a bit over 1.2A, this is fine for a 1A charge.
It also works on 120VAC.
No problems running one hour at 1A.
M1: 41,1°C, HS1: 62,0°C
M1: 55,0°C, M2: 40,7°C, HS1: 60,0°C
HS1: 47,8°C
M1: 48,0°C, M2: 40,0°C, HS1: 61,6°C
At 0.5A the noise is 10mV rms and 204mVpp.
At 1A the noise is 12mV rms and 268mVpp.
Tear down
My vice and a mallet could open it.
There is a fusible resistor in series with the connection, looks like it was an afterthought.
It has two capacitors (C1 & C2) on the mains input with a inductor (L1) between, there is a mains switcher transistor (Q1)..
On the low volt side there is a rectifier diode and two capacitors with an inductor between.
On the first image the output inductor can be seen, on the second image the input inductor can be seen. There is also a bit of the fusible resistor visible.
There is some isolation paper on the this side to prevent the mains input connection touching the circuit board.
On this side is a bridge rectifier, the mains switcher IC and coding of the usb connector.
Safety distance looks good.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
Charger works fine with fairly low noise and is safe, but the coding is a bit old and 1A is fairly low current by todays standard.
Notes
Charger was supplied by Pro backup (probackup.nl)
How does a usb charger work?
