BlitzWolf 4 usb and QC BW-S7
Official specifications:
Brand: BlitzWolf®
Model: BW-S7
Plug: EU, US, UK,AU
USB Port: 18W(Max) QC3.0 Port + 22W(Max) 4.4A 4-Ports
Total Power: 40W (Max)
Input: AC 100-240V~50/60Hz 1A
Output: 4-Ports: 5V/4.4A (Max)
QC3.0 Port: 3.6-6.5V/2.4A, 6.5-9V/2A, 9-12V/1.5A (Max)
Color: White
Weight: 400g±10g
Certification: CE,FCC,RoHS,Qualcomm QC3.0
I got it from banggood
It was in a brown cardboard box without any information except the type number.
In the box was the charger, a mains cable and a instruction sheet.
Measurements
Power consumption when idle is 0.17 watt
USB output is auto coding with Apple 2.4A, Samsung, DCP and QC2, but only 5V
The 4 USB outputs are in parallel
QC output is auto coding with Apple 2.4A, DCP and QC3
Minimum QC3 voltage is 4.4V, then it resets to 5V.
Weight: 149g
Size: 91.5 x 60 x 24.4mm
There is no individual port protection on the usb outputs.
It is the same on this output
When all four is used the maximum current draw is about 4.7A this matches fine with a 4.4A rating.
It is the same at 120VAC
On 5V the QC output can deliver about 3.3A
At 9V the output current is down to 2.3A, but the overload protection do first kick in at 3.3A
And 1.8A at 12V
Running the charger with 4.4A on usb and 12V 1.5A on QC it could handle 60 minutes.
M1: 69.3°C, M2: 63.2°C, M3: 54.4°C, HS1: 72.9°C
HS1 is the usb transformer, M1 is the mains switcher transformer and M2 is the heatsink for the rectifier transistor.
M1: 48.9°C, HS1: 64.1°C
HS1 is the QC transformer, here it is very close to the box and will heat it, next to HS1 is the QC rectifier transistor.
M1: 77.0°C, HS1: 85.8°C
HS1 is the large QC switcher, it is hot and only some of the heat reach the plastic. M1 is the gray heat transfer pad, it is moving some heat from the circuit board.
HS1: 56.9°C
HS1 is the rectifier transistor for USB.
HS1: 70.0°C
At 0.5A the noise is 6mV rms and 63mVpp.
At 1A the noise is 6mV rms and 70mVpp.
At 2.5A the noise is 6mV rms and 78mVpp.
At 0.5A the noise is 17mV rms and 503mVpp.
At 2.5A the noise is 53mV rms and 631mVpp.
At 0.9A the noise is 42mV rms and 573mVpp.
At 1.2A the noise is 26mV rms and 657mVpp.
Tear down
Some pressure in my vice and I could break the bottom off. The gray stuff can transfer heat, but there is not anything making heat where it is placed. If it had covered the big black chip it would have made sense.
At the input is a fuse and two common mode coils, both placed under the heatsink and one hidden in yellow tape. The rectifier is also placed under the heatsink. On the heatsink is the mains switcher transistor for USB. There are two blue safety capacitors, one for each transformer.
At the low volt side is two rectifier transistors, for USB a large one on a heatsink for QC a SMD part. Just behind the QC USB connector is the QC controller chip.
A look under the heatsink.
On this side is the mains switcher controller for USB (U9) with opto feedback (U5). The low volt side for USB output contains a synchronous rectifier controller (U8), a reference (U10: 431). It also looks like there is some current detection with a very small resistor (R7C: 10mOhm), another reference (U3: 431) and probably an OpAmp (U4). The four usb output has two dual auto coding IC’s (U6 & U7).
The QC circuit is basically one IC (U1: INN2215K) that controls everything, except the QC part.
Some of the distances are slightly on the low side, the opto coupler has only 5mm pin spacing.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
This is a fairly standard USB and QC charger, the output power on the 4 usb connectors is a bit low for 4 connectors, there is only power for two high power devices (With the QC port it means 3 high power devices). The ports are auto coding and the four ports a low in noise
Notes
How does a usb charger work?
