Camelion AA Max 2500mAh (White)
Official specifications:
Frame size: AA
Dimensions (Ø x L mm): 14,1 x 50,5
Weight (g): 29,0
Electrochemical System: Nickel-Metal Hydrid
Capacity typical: 2500mAh
Capacity minimum: 2350mAh
Nominal Voltage: 1,2V
Jacket: Plastic
Retains 90% after 6 months, retains 85% after 1 year.
/Camelion%20AA%20Max%202500mAh%20(White)-info.png)
Maximum temperature raise at different discharge currents: 1A:+1,6°C, 2A:+4,1°C, 3A:+7,1°C, 5A:+13,6°C, 7A:+19,0°C, 10A:+18,9°C
Camelions high capacity and LSD (Low Self Discharge) NiMH batteries.
/DSC_2004.jpg)
/DSC_2005.jpg)
/DSC_2013.jpg)
/DSC_2014.jpg)
/DSC_2015.jpg)
/DSC_2016.jpg)
/DSC_2017.jpg)
/Camelion%20AA%20Max%202500mAh%20(White)-Capacity.png)
The discharge curves look fairly normal, the cells has not been used for some time and the first trace (0.1A) do not get full capacity.
/Camelion%20AA%20Max%202500mAh%20(White)-CapacityTime.png)
/Camelion%20AA%20Max%202500mAh%20(White)-CapacityTimeHours.png)
/Camelion%20AA%20Max%202500mAh%20(White)-Energy.png)
/Camelion%20AA%20Max%202500mAh%20(White)-PowerLoadTime.png)
/Camelion%20AA%20Max%202500mAh%20(White)-CurrentTest.png)
/Camelion%20AA%20Max%202500mAh%20(White)-Charge.png)
Conclusion
Performance of these cells is not in top, but they work fairly good.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
